Old 06-13-2012, 12:29 PM   #1
CC69Rat
CC69Rat's Avatar
Shock part numbers ? Bilstiens anyone?
70 GMC SWB, Coil spring rear. ECE relocation brackets in the rear.
4.5/6" drop acheived by 2.5" spindles and 2" springs up front, with 6" drop spring in the rear. McGaughys spindles, big brakes, (if that matters) Hotchkis springs, Hellwig sways.
I'm looking for Bilstien shocks. Does anyone have a similar setup and may possibly have part numbers for the right length I need?
Hotchkis has adapters with their springs where you can adjust the rear drop if you need to. (essentially 5.5" rear drop) But I will get it as low as I can without notching.
KYB ? .. what would you run? I wouldn't need shock relocation up front with a 2" spring drop correct? Ideas? Suggestions?
Thanks ..
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 06-13-2012, 05:08 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Shock part numbers ? Bilstiens anyone?
RCD has spec'ed Bilstein shocks and they basically fit the same as stock spec shocks. CPP sells them (as I am sure others do) but for some reason they don't list online the rear ones for coil setup, only the leaf. They have them in their computer though, you just have to ask.
'63-'72 Fronts are # 55-R033
'63-'72 Leaf Rears are # 55-R042
'63-'72 Coil Rears are # 55-R034
I have put them on my '65 Panel but I have not driven it yet so I can't comment on the ride. I am also using a rear shock relocation kit. I am still doing some mock up to verify I can get the axle to touch the frame (without stock bump stops) and not bottom out the shocks.
If you are going to ever notch the frame, these would be too long in the rear.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-17-2012, 02:35 AM   #3
SCOTI
SCOTI's Avatar
x2.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-17-2012, 02:19 PM   #4
CC69Rat
CC69Rat's Avatar
Much appreciated fellas..
Chad
Old 08-22-2012, 11:30 AM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Rat, dunno if you've purchased already, but if you don't mind the 'traditional' Bilstein yellow/blue vs the black RCD/CPP shocks, you can save a little cash by using these part numbers:
Front - 24-192941 (F4-B46-1185-H2)
Rear - 24-002486 (F4-B46-0248-H0)
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 09-17-2012, 01:11 PM   #6
CC69Rat
CC69Rat's Avatar
Gringo -- you know those will work? I just noticed this post. I'm getting my shocks today. I don't mind the yellow / blue.
Thanks man.
Chad
Old 09-17-2012, 01:18 PM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
That's what I purchased and have sitting on the shelf, but have yet to install. Definitely good at stock height, but may need relocation on dropped trucks. Check out my build thread for compressed/extended lengths here. I will likely be relocating the upper mounts both front and rear, but they may work without it...
-Chris
Old 09-18-2012, 02:37 PM   #8
TheSuspensionSource
Have you considered Belltech Street Performance shocks? The progressive rebound tuning will complement large aftermarket wheels, keeping the ride smooth and firm. Belltech Street Performance shock absorbers are the ideal balance between performance and comfort.
Street Performance Shock Features:
  • Metal dust boot
  • Hardened Chrome 15mm piston rod
  • Triple lip NBR rod seal
  • Teflon guide bushing
  • 35mm piston with low friction piston Tefl on seal
  • Performance rebound valve design
  • 55mm wide body for increased oil volume
  • 35mm performance compression valve
  • Reinforced OEM quality rubber bushings
63-72 1/2-TON C-10 Pickup Part Numbers:
Front
  • 0" to 3" Spindle Drop 2104HA
  • 1" to 4" Spring and/or Spindle Drop 2103HA
Rear
  • 0" to 1" Drop 2210AA
  • 2" to 6" Drop 2208AA
Measurements:
2104HA Extended: 14.76" Collapsed: 10.00"
2103HA Extended: 14.02" Collapsed: 9.61"
2210AA Extended: 20.51" Collapsed: 12.99"
2208AA Extended: 18.50" Collapsed: 12.01"
The cost of a set of four is $220 but I can offer a forum discount for $200 with free shipping to lower 48 states.
TheSuspensionSource is offline   Reply With Quote
Old 09-18-2012, 05:03 PM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by TheSuspensionSource View Post
...63-72 1/2-TON C-10 Pickup Part Numbers:
Front
Rear
Measurements:
2208AA Extended: 18.50" Collapsed: 12.01"...
Those dropped shocks are eerily similar in length to stock replacement, as well as the Bilsteins:
-----------------(F)--Bilstein 24-192941--------Monroe 33033
Extended----------------15 1/2-------------------14 5/8
Compressed-------------10 3/8--------------------10 1/8
Travel-------------------5 1/8---------------------4 1/2
-----------------(R)--Bilstein 24-002486--------Monroe 32301
Extended----------------18 7/16-------------------18 1/4
Compressed--------------12 3/16-------------------11 7/8
Travel--------------------6 1/4---------------------6 3/8
-Chris
Old 09-18-2012, 05:52 PM   #10
TheSuspensionSource
The sizes may be similar but the rebound valve will be different. Belltech shocks are designed around lowered/performance suspension when most of brands are designed around OE suspension.
