Old 06-13-2012, 02:19 PM   #1
badriand
badriand's Avatar
Airbag tank/compressor etc ?
Been searching but haven't really found my answer yet. Thinking of doing bags but just want front and back not side to side. What setups are some of you guys running that wasn't too expensive for tank/compressor valves etc. The basic set for just that is like 1000$ for ridetech. thx
badriand is offline   Reply With Quote
Old 06-14-2012, 01:20 AM   #2
cb1965
cb1965's Avatar
Re: Airbag tank/compressor etc ?
You should ask in the suspension section.
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 06-14-2012, 08:38 AM   #3
Slammed50
I have used ride techs set ups in the last three bag jobs I have done and am using the same one on my '63. Great stuff. My buddy has been using his for over 15 years with no issues.
Check out my build thread for my '63:
http://67-72chevytrucks.com/vboard/s...49#post4806049
Slammed50 is offline   Reply With Quote
Old 06-14-2012, 09:35 AM   #4
badriand
badriand's Avatar
I ordered rear setup and will add front at some point, guess i will just have to save up the $.
Old 06-14-2012, 06:35 PM   #5
Malibob
Malibob's Avatar
I would encourage you to do the FBSS setup. Not to ride sideways or anything but the truck could lean when you get in it, it will roll pretty bad in longer turns and could even lean at low pressure with just a F&B setop. I ran a F&B setup on my old truck with a swaybar which helped but when I switched it I was much happier.
My new rig had a similar setup and I just finished switching that over too.
If you are going with manual valves the cost isn't too much worse. Worth the extra $$ though.
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
Old 06-14-2012, 10:49 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Malibob View Post
I would encourage you to do the FBSS setup. .....
Good advice! You will be disappointed in the way your truck leans around corners if you don't go with four corner controls.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-15-2012, 12:38 AM   #7
badriand
badriand's Avatar
Thx. Is that what the 4 way system is?
Old 06-15-2012, 08:03 AM   #8
Malibob
Malibob's Avatar
yep. all it is is 4 switches (running individual lines to each bag) and 2 gauges (showing pressure of each bag)
Flickr
Old 06-15-2012, 10:36 AM   #9
andrewmp6
Talk to some of our vendors you can get everything cheaper then a grand.
andrewmp6 is offline   Reply With Quote
Old 06-15-2012, 11:24 AM   #10
badriand
badriand's Avatar
thx for the help
Old 06-15-2012, 12:14 PM   #11
Pro Performance
Pro Performance's Avatar
I also recommend the FBSS setup for the same reasons mentioned above. Let me know if we can help you out. We have put together our own kits that have everything you need to plumb right into the bags. Whether it be a single compressor system or dual compressor system.
Both of those system are around $1,000, but if you want something even more affordable, we have a manual valve setup for $575.
1/4" Manual Valve Air Management System
We do have out Pro2 on special this month which is the dual compressor air management system. If you're interested in any air management system we carry, just let me know and I can help you out and save you some money.
Travis
Pro Performance is offline   Reply With Quote
