Old 06-13-2012, 03:13 PM   #1
klutz51
drop i beam
looking to do a drop i beam on my 51. anyone know the best place to get one, dont want fancy this is going to see a lot of drive time.
klutz51 is offline   Reply With Quote
Old 06-13-2012, 04:02 PM   #2
cotsi95
Re: drop i beam
I assume your talking about the front axle. If so check out http://www.droppedaxles.com/ i've heard nothing but good about sid's work. I plan on using him for mine.
Where are you at in colorado? I'm in Fort Collins.
cotsi95 is offline   Reply With Quote
Old 06-13-2012, 07:26 PM   #3
klutz51
Re: drop i beam
i am in parker thanks for the info, i did look at his sight and liked what i saw, but wasnt sure if buying a new dropped axe was the way to go.
Old 06-14-2012, 08:10 AM   #4
focusedontheprize
focusedontheprize's Avatar
Re: drop i beam
Klutz -
As 48chev mentioned before in your other post (http://67-72chevytrucks.com/vboard/s...d.php?t=527863 you send him your front axle and he will do the stretching.
You should start up a build thread over in the "Projects" section and list out what your looking to do. It sounds from your questions you may be going the same way I am doing mine.
focusedontheprize is offline   Reply With Quote
Old 06-16-2012, 12:27 PM   #5
zenchal26
zenchal26's Avatar
Re: drop i beam
got my 3" drop from sids good guy good service.
zenchal26 is offline   Reply With Quote
