05-15-2003, 08:41 PM | #1 |
spacing between leafs
I just found out the space between springs (leafs) side to side is different on 4 wheel and 2 wheel drives. Why is that? I thought I had a direct bolt in but I will have to move the pads on the rear end.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
05-28-2003, 02:30 PM | #2 |
why would the spacing be different on a 4 wheel drive?
05-28-2003, 02:34 PM | #3 |
Member since 2000
spring rating?
05-28-2003, 02:42 PM | #4 |
the spacing between springs from side to side is 2" closer on the 4 wheel drive. I will have to move the pads on the rear end. I was very surprised to find this out.
05-28-2003, 02:46 PM | #5 |
Resident Curmudgeon
Though I can't confirm the validity of this, I was told that the spacing was wider on 2wd trucks to better stabilize top-heavy loads like camper shells. Since the optional leaf springs were popular on "camper specials" and most camper-ready trucks were 2wd, this makes some sense.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
05-28-2003, 03:04 PM | #6 |
Fabricate till you "puke"
the longhorns also have the narrower spacing(40" c to c ) if I remember. The shape of the frame rails dictate the spacing(longhorn & 4wd = straight rails), & the other leaf trucks(pickups) have the bowed rails(same as a coil setup)......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
