Old 06-14-2012, 03:31 AM   #1
oldsnakebite
oldsnakebite's Avatar
200-r4 trans suggestions
Truck is an 64 short stepside and just purchased a 66 250 straight six engine that I plan to rebuild and install. Current motor is 350, powerglide with 12 bolt 3.73 in the rear. Would like to keep the 3.73 gears, go with the straight 250 and overdrive trans. Any suggestions on what years I should look for in an 200-r4. Heard their the same length as a th350 and PG. Looking for that friendly highway feeling.
I have not failed. I’ve just found 10,000 ways that won’t work.
oldsnakebite is offline   Reply With Quote
Old 06-14-2012, 07:17 AM   #2
brokenspoke
brokenspoke's Avatar
Re: 200-r4 trans suggestions
First of all its a 200-4r transmission...check out '' Bowtie Overdrives "
brokenspoke is offline   Reply With Quote
Old 06-14-2012, 06:13 PM   #3
gimmy 64
i went with gearstar. they build them for your truck --gear ratio,tire size, motor etc. plus they have a 3 year warranty. also they come with everything you need.--dip stick to bolts even tranny fluid and cooler
gimmy 64 is offline   Reply With Quote
Old 06-14-2012, 11:26 PM   #4
siggyfreud
siggyfreud's Avatar
People get confused because the next iteration of it was the 700R4
siggyfreud is offline   Reply With Quote
