Trans linkage
Do I need a special linkage to connect the column shift to the 4L60e? The one on my truck is just a rod with a bolt and about 3" short.
Posted via Mobile Device |
Re: Trans linkage
I'm not sure about your specific application but there is one made by Kugel Komponents that can be set up to the length you need. Not too expensive.
here is a link but there are many places that sell it. http://www.kugelkomponents.com/zenca...=index&cPath=2 |
Re: Trans linkage
Ive never had to, But you got to have all the pieces to the linkage.
Shifter rod...Rod C Bell-crank...Lever asm. B Trans lever A The Bell-crank fits into a bracket on the frame with a Nylon bushing & spring (keeps it from rattling). Lokar stuff is JUNK dont buy that overpriced aluminum crap. |
Re: Trans linkage
I must have misplaced some parts. I just have the rod and the bolt that tightens to that horizontal plate.
Re: Trans linkage
Lokar claims that their kit will work - I had a lot of luck with them in the past. They also make a pretty nifty cable shift bracket and assembly that works with the column. I was considering going that route - but I plan use my B&M ratchet as is for the time being.
#6 | |
Re: Trans linkage
Since I had some binding I did look at the lokar unit and it seemed very nice. In the end I swapped out for a T56.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Truck and auto performance nut
Re: Trans linkage
I went with a Lokar trans mount on my 200-4r because I had plenty of room. Wound up having to bend the bracket to make it fit and then could only use it when the exhaust was cool. Not a fan.
Just put a new 4L85e in....and I got a Hughes "standard tube type" locking dipstick for it. 'nuff said.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Re: Trans linkage
OSALTYONE,
Give us a call here at Lokar. We will talk you through the different options available for your applacation. Our products have a lifetime warranty and we build applacation specfic products. It should not be a problem to get you into what you need. Toll 1-877-469-7440 |
Re: Trans linkage
Well there you go top notch service. Their products have always been great.
#10 | |
Re: Trans linkage
Re: Trans linkage
what about with longtubes? mine lt's are awful close to the factory linkage, hopefully i
can get it to work. |
#12 | |
Re: Trans linkage
Thanks for all the replies, I got the one from Kugel since they were so close to my place and seemed like it could work.
#13 |
Re: Trans linkage
Has anyone stopped & looked at the Direct Link of a aftermarket column shifter kit???? It does not allow for engine/tramission movement, Frame flex, & Cab mount movement, The factory linkage is engineered to account for this.
| Bookmarks |
