06-14-2012, 09:33 PM | #1 |
Better Hub Bearings
I have an 03 Z71 Tahoe that has stock wheels and tires on it still. For some reason I am going thru bearings on the right side and fairly quickly. Has new upper control arm and ball joints. Alignment is great. Does anyone know of a better hub bearing? I have used both Gm and aftermarket parts store replacements and they last about the same. A few months. I havent been off road in years because its pretty much illegal out here and i really dont want to goto jail.
Posted via Mobile Device |
06-14-2012, 10:11 PM | #2 |
Re: Better Hub Bearings
Are you torqueing the drive axle nut to specs or using an impact? Also, is the big o-ring ( in steering arm assy ) in good condition and lightly lubed that seals around the outside of the cv joint? It seals out water and gook.
06-14-2012, 10:23 PM | #3 |
I do not have an impact. I have only hand tools and used a 1/2 inch drive torque wrench to torque the hub nut to gm's spec. As far as this o-ring if it is a rubber o-ring then no I do not have one. For that matter there is not one in any of my trucks. However there is a metal sleeve thing pressed onto the bearing housing at the end of the shaft where it would sit inside the knuckle that would be directly behind the bearing.
06-14-2012, 11:46 PM | #4 |
man i have replaced the right bearing twice. once at 130k and then at 170 or so. i dont even have a torque wrench or knew you should use one. i just tightened it.
That seal on the steering assembly on mine i have never noticed. the axle end is welded shut and the other side i dont know... I think you may be right about the moisture and gook though. I dont know where that would get in. Wish i was more help!
2001 Tahoe 1978 K30 |
06-15-2012, 08:13 AM | #5 |
i normally install mogg wheel bearings at work never had one come back
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
06-15-2012, 03:46 PM | #6 |
I just ordered hub assemblies for my 04 2500HD. 175,000 kms on the original units.
I did some research at dieselplace.com and they recommend the Timken units. I believe they have a life time warranty. I ordered mine from Rock Auto for $160 /side plus shipping.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
06-15-2012, 04:50 PM | #7 | |
+1 on Timken... great products |
06-15-2012, 05:25 PM | #8 |
Yeah, I paid $100 a piece to have them shipped from Rock Auto to me in Northern Canada. Total of $550 with taxes and handling.
I emailed a GM dealer in Texas I have bought parts from before at great prices and he quoted me just over $500 for a pair of assemblies and then I needed to ship them. Timken are also available on eBay. I think I could have saved a bit on shipping using an eBay seller.
