Old 06-14-2012, 10:03 PM   #1
raymo66
raymo66's Avatar
Exhaust routing help
Ok need some ideas on running some exhaust on a 64 C10 Have headers right now nothing else yet . Has anybody run the pipes on the outside of the frame back to the bumper instead of inside the rails and getting over the rear end and around the track bar going outside might be tight by the rear tire and frame so is this a good or bad idea? Hope somebody can help
raymo66 is offline   Reply With Quote
Old 06-15-2012, 09:48 AM   #2
ChevySixty6
ChevySixty6's Avatar
Re: Exhaust routing help
I just did that this week. I haven't run it all the way to the bumper yet, as i'm looking for a difft bumper. But i did tell them to set it up to go between the spring and tire.
Do a search on here, as i've seen some pics of others who did this. That's where i got the info from. I don't remember where the thread was though.
Members i've met: LiLRed66
ChevySixty6 is offline   Reply With Quote
Old 06-15-2012, 09:53 AM   #3
Rich 5150 69
Rich 5150 69's Avatar
Here`s one thread http://67-72chevytrucks.com/vboard/s...xhaust+routing
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 06-15-2012, 10:13 AM   #4
1963c-10
1963c-10's Avatar
If the 63-72 frames are supposed to be almost the same, couldnt a 67-72 kit work on the 63-66? Im sure there would be some minor mods, but has anybody tried?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-15-2012, 10:20 AM   #5
Rich 5150 69
That is what I was thinking and buying a kit to do it with from magnaflow.
Old 06-15-2012, 09:45 PM   #6
raymo66
raymo66's Avatar
hey thanks guys Iam thinking of going outside the rails using mandrel bends to do this two 45s to make a offset to the out side of the frame and found a place that has a 18 degree mandrel bend that would get you started up the frame past the rear spring and another 18 bend to make the offset a straight shot out under the bumper still mapping this all out using store bought bends
Old 06-18-2012, 01:19 PM   #7
1963c-10
1963c-10's Avatar
Get pics if you do
