Old 06-14-2012, 10:28 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Heater box/Evaporator box refinishing
Ideas and pics for heater box refinishing please. I think I will just prime and paint it when I get my truck painted in a few weeks.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 06-14-2012, 11:35 PM   #2
srea76
srea76's Avatar
Re: Heater box/Evaporator box refinishing
subscribed.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern"
1984 Silverado
Red Baron-72 c10 Project
srea76 is offline   Reply With Quote
Old 06-15-2012, 12:46 AM   #3
mcmlxix
Collector of Projects
mcmlxix's Avatar
I was going to have mine rhino-lined ... but ended up just using a soft wire wheel and putting it back on...
Rich
1972 K5 Blazer CST Click HERE
Old 06-15-2012, 12:54 PM   #4
davepl
davepl's Avatar
I just did mine... new heater core, new gaskets, etc. Check the heater resistor while you have it out, it's easier to get at.
I wound up sanding the scratches out of it and painting it with Eastwood Underhood Black.
Here's a tip: the heater core is held in by two thick wire supports that bolt in. My core was an aftermarket replacement that didn't fit tightly, so I slit a piece of fuel line lengthwise and slid it over those wires before boltiong it all back in. This held it in place without any movement and should prevent a lot of rattles in the future.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-15-2012, 01:34 PM   #5
notsolo
notsolo's Avatar
I washed/ cleaned off dirt etc rubbed Mastercoat black (this is like POR15 but I like it better) over rough surface this made it look like what I thought was original...
notsolo is offline   Reply With Quote
Old 06-15-2012, 03:01 PM   #6
AirSpeed
AirSpeed's Avatar
I had a broken heat box in my 70, I fixed the crack with fiberglass then sprayed it with a texture spray made by Plasticoat, it looks like bed liner but a little more coarse. I then sprayed it satin black. No pics but it really looked nice. I used the same stuff on the interior heater box on my 69 and 72. In the past I have coated similar items with a heavy coat of paint then dusted the wet paint with sand then another coat of paint. It really works well.
AirSpeed is offline   Reply With Quote
Old 06-16-2012, 10:11 AM   #7
dfwright
dfwright's Avatar
Check out this thread where they used Gibbs oil to freshen up the box.
Gibbs oil~ the test
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 06-16-2012, 09:43 PM   #8
71 super
71 super's Avatar
In both of my restorations, I took the box out and when no one was home gave it a scrub in the bath tub . After drying it I purchased some cast blast or similar cast iron colored paint (it is actually pretty close to the original finish on the box) sprayed the box , replaced the evap cores, used stainless screws to bolt back together new gaskets etc.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 06-16-2012, 11:02 PM   #9
jocko
jocko's Avatar
That's awesome!
Old 06-17-2012, 05:53 PM   #10
oldspowered67C10
They came unfinished stock. I just sanded mine down to fresh material and the painted it w/ semi-gloss clear, looks correct and brand new.
oldspowered67C10 is offline   Reply With Quote
