what wrong with this 12 bolt ?
looked @ a 12 bolt 3:73 posi from a 77 1/2 t 4x4 yesterday with new richmond ring & pinion but on the left of the ring gear & right of the posi were round shims? very loose different thickness' & one actually came out broken i passed on it not knowing what was going on here anyone explain this i would like it for the $200 with springs,16" white spokes & 1 excellent tire but dont have the expeience to work the internals thanks
1990 chevy 4x4 with a 1940 IHC body |
Re: what wrong with this 12 bolt ?
A diff has to to be shimed in for it to work prefectly,Its not hard to build one if you know what your doing.If you have time you can read this http://www.pirate4x4.com/tech/billavista/Gear_Setup/
Sounds like they didn't get the bearing preload tight enough and it kicked a shim out/broke. If it wasnt driven too long that way, everything should be ok. I have come across this before and i reset-up the ring and pinion and everything was fine. Its still driving with no failure.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
