Old 06-15-2012, 10:40 AM   #1
dagall
In Cab Fuel Fill Opening
What have you guys used to seal the opening to the cab for the fuel tank after it has been removed. The cap is "rigged" closed, but would like some other ideas. Don't want to weld and paint the cab right now. Have seen one or two posts about a gas tank delete plate, but don't see any real info about it.
1972 Chevy C10
Shortbed/Wood
Starting LS1 GTO Swap
dagall is offline   Reply With Quote
Old 06-16-2012, 10:06 PM   #2
dagall
Re: In Cab Fuel Fill Opening
NOBODY... Really
1972 Chevy C10
Shortbed/Wood
Old 06-16-2012, 10:16 PM   #3
FL71C10
Try, this
http://67-72chevytrucks.com/vboard/s...d.php?t=250995
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 06-16-2012, 10:49 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I've never understood why cats get so bent out of shape if nobody has the answer or any input.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-17-2012, 09:09 PM   #5
1972RedNeck
1972RedNeck's Avatar
I saw a truck with a factory rubber plug in the hole. I think it was an F600
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 06-18-2012, 12:40 PM   #6
coop34
For a temporary solution, I cut the neck off of the old tank, slipped it into the hole and put the cap on. The rubber grommet holds it in there fine. I just have to make sure nobody borrows my truck and goes to fill it up!
coop34 is offline   Reply With Quote
Old 06-18-2012, 12:49 PM   #7
29od1
I thought about doing the same and weld a plate on the cutoff end of the filler tube. That way someone doesn't accidentally fill the cab up with fuel
29od1 is offline   Reply With Quote
