Old 06-15-2012, 11:38 AM   #1
texastruckjunky
texastruckjunky's Avatar
Question Electrical problem. Can anyone help?
I have a 1981 1/2 ton. I have recently replaced the sending unit for the gas tank, and now when I turn my lights on the gas gauge goes to empty. Can anyone tell me why or how I might be able to fix this. I dont do a lot of night time driving, but I dont want it to turn into a bigger problem later. Thanks for your help in advance.
Rey
Life is to short to drive anything else
texastruckjunky is offline   Reply With Quote
Old 06-15-2012, 01:57 PM   #2
rs72z
rs72z's Avatar
Re: Electrical problem. Can anyone help?
Make sure you grounded the sending unit. Check all the grounds on th front end also.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 06-15-2012, 02:16 PM   #3
hatzie
Moderator
hatzie's Avatar
If it works till you turn on the headlights there's probably a ground problem behind the instrument cluster.
There's a big splice where the Black cluster plug grounds are all connected to a single ground wire from the ground bar under the dash. The Pink/Black cluster power wires have the same type of splice.
The panel lamp ground is probably wonky.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-15-2012, 10:07 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
yup sounds like a ground issue
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-15-2012, 10:07 PM   #5
texastruckjunky
It was all working till this morning, I replaced the fuel sending unit about a month ago. But thanks for the help anyways.
hatzie: Thanks for your reply I'll have to check that in the morning. I remember when I replaced the sending unit the guage still did not mark, when I pulled the cluster out the plug in the back had corrosion on it like the truck had gotten wet or was under water at some time. I think it was under water cause there was also leaves, twigs and dirt all up under the dash. So I replaced the cluster with another one i had . So i'll get back in there toomorrow and check it again. Thanks
Rey
