Old 05-15-2003, 10:42 PM   #1
nosto
Flamin' Bass
nosto's Avatar
Inside door handle thingy question...
Well, the Service Manual calls it a door remote. Both of mine have this spring like piece of metal wrapped around the shaft (see where the arrow is pointing?). This spring is just sitting there, loose.
Is it supposed to act like a real spring and provide some tension when you pull on the door handle? Am I looking to order new door remotes to replace these broken ones, or is this how they should be?
Thanks,
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 05-15-2003, 10:49 PM   #2
jhow66
jhow66's Avatar
Sorry but it looks like they are broke . These springs return the door handle back to the position it was in when you open door.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 05-15-2003, 10:54 PM   #3
Tim Christian
Tim Christian's Avatar
Smile
I have these in stock if I can help you just let me know. Thanks Tim
Tim Christian is offline   Reply With Quote
Old 05-15-2003, 10:57 PM   #4
XXL
Seņor Member
XXL's Avatar
Re: Inside door handle thingy question...
Door relay.
Spring is broken, hence the lack of tension on it.
XXL is offline   Reply With Quote
Old 05-15-2003, 11:06 PM   #5
wHATANERD
wHATANERD's Avatar
I'de replace both, there only about 15 bucks each.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 05-16-2003, 05:53 AM   #6
Seke69
Space Cadet
Seke69's Avatar
I have one that's broken and one that isn't, they should spring the handle back to it's original position.
the spring may not be seated right or it's worn/broken.
Seke69 is offline   Reply With Quote
Old 05-16-2003, 09:35 AM   #7
MOTHERTRUCKERS
We stock GM NOS and reproduction door remotes if interested.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 05-16-2003, 03:10 PM   #8
casey
casey's Avatar
for 15 bucks they aren't worth playing around with, I fixed mine but didn't realize you could get them new
casey is offline   Reply With Quote
