Old 06-15-2012, 05:53 PM   #1
byates2
byates2's Avatar
Re-doing the drums
I'm replacing the brake shoes, and changing the drums from 6 lug to 5 lug
ive never done drum brakes before so i'm wondering if it looks right in the photos.
Also, how do you adjust them, or are they self adjusting??
1967 C10 Long Bed, Soon to have a 350
1997 Chevy 2500 454 BB
byates2 is offline   Reply With Quote
Old 06-15-2012, 08:48 PM   #2
70CHEVYBB
70CHEVYBB's Avatar
Re: Re-doing the drums
looks good, you just need to start with your adjuster all the way in. Then put the drum on and turn the adjuster out until there is a small amout of drag on the drum when you turn it. Make both sides feel the same and your good.
70CHEVYBB is offline   Reply With Quote
Old 06-15-2012, 09:16 PM   #3
byates2
byates2's Avatar
How do you turn the adjuster out with the drum on?
Old 06-15-2012, 09:17 PM   #4
byates2
byates2's Avatar
ive looked and looked and cant find any slots or holes to get to the adjuster once the drum is put on
Old 06-15-2012, 09:18 PM   #5
Tinkermc
sounds like how I would do it, the adjuster is the small gear piece at the bottom and there is a slot in the rear to make adjustments.
Tinkermc is offline   Reply With Quote
Old 06-15-2012, 11:47 PM   #6
byates2
byates2's Avatar
in the rear? the backing plate? i cant seem to find a slot at all . I know where the gear piece is but it seems solid metal where the piece sits
Old 06-16-2012, 12:01 AM   #7
WORP67
Sometimes you have there is a knock out like in a electrical panel then put in a rubber plug.
WORP67 is offline   Reply With Quote
Old 06-18-2012, 06:26 PM   #8
byates2
byates2's Avatar
I have no idea where the slot could be. there is absolutley no slot back there. Are they self adjusting. these are the rear brakes just to clarify if there is a difference from the front
Old 06-18-2012, 07:45 PM   #9
67c10rustbuket
67c10rustbuket's Avatar
I swear there is supposed to be a knock out or plug but I just looked at both my rearends (70 & 72) and neither has a knockout. I was taught to adjust them with the drum off by turning the adjuster until there was a slight friction when putting the drum on then remove the drum and back it off a turn so there was no drag. Then being self adjusting drive in reverse in the driveway and slam on the brakes and this will self adjust them. Thats how I was taught a long time ago by my dad anyway. Anyone else heard of this method?
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
