billet carrier bearing How Good?
Hey Guys, just wondering how many of you use the billet carrier bearing and how you like it, since it has the poly bushing in it is there more vibration than the rubber bushing , just trying to get some info on this, tired of putting a bearing in every year. Thanks In advance for the info
Re: billet carrier bearing How Good?
I put one on my 70 LWB. At first, it seemed Ok but developed a roar at around
60-70 MPH. The problem was that there was no flex to compensate for up and down movement of the differential. The old soft rubber center bearing allowed for some back and forth movement into the transmission tail shaft. I had a drive- shaft fabricated that has a slide shaft in the rear section. This cured the roar and also some vibration that I suspected was in the drive shaft. I found a guy on E-bay that makes the drive shafts. He has a store front site and supposedly travels to a lot of shows in the West. I sent him the measurement and about a week later received the drive shaft. I think the price was around $150. It has been awhile back so do not hold me to that. I am sure that I have the receipts here somewhere and will look them up if you want. The new shaft fit perfectly and is well balanced. After driving the truck for over 30 years and several of the OEM type bearings, I consider it to be an improvement and would do it again. EdB |
![]() Join Date: Apr 2010
Interested in where you got it.
Interested in the details as well.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
I have used one for over 6 years with no problem
Fuzzy |
Old member
I was going with one also but at the time couldn't afford it. I have a good rubber one that is going on 5 years now. I had the drive shaft balanced and put together by a local place called Clines in Greenville SC. They know there stuff.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
