Old 06-15-2012, 10:27 PM   #1
tiny68
Exclamation Parts swap?
I have the body and frame of a 1972 suburban. It is a 4x4 half ton. It is literally just the body and frame. I don't have engine, axles, driveline, transmission, steering, etc....Crazy I know
I found a 1971 4x4 half ton Custom/10 that runs and has all the parts I need. I think I can take all the parts off the pickup and put them on my burb without any modification. AM I RIGHT?
tiny68 is offline   Reply With Quote
Old 06-15-2012, 11:19 PM   #2
vectorit
What?
vectorit's Avatar
Re: Parts swap?
Yes.
But you will need to get a burb drive shaft if I am not mistaken.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 06-29-2012, 07:50 PM   #3
capev86
Re: Parts swap?
don't they share the same 127 inch wheelbase?
capev86 is offline   Reply With Quote
Old 06-29-2012, 08:04 PM   #4
70GreenBurb
70GreenBurb's Avatar
Re: Parts swap?
My 70 Burb has a two piece driveshaft but I has seen references to swapping in one piece shafts so I think even the shaft should be usable if the truck also has the 127" WB.
1970 Custom 10 Suburban- 350/700R4 w/3.07 Gears
1961 Shasta trailer
2001 Tacoma Reg Cab (Mini Taco)
Photobucket pictures- http://m1254.photobucket.com/albumlist/vintage6170
70GreenBurb is offline   Reply With Quote
Old 06-29-2012, 08:19 PM   #5
70GreenBurb
Re: Parts swap?
Do a forum search with the term driveshaft and suburban. Looks like several good threads.
1961 Shasta trailer
