Old 06-16-2012, 01:56 AM   #1
syncrov69
syncrov69's Avatar
Unhappy Cluster left flasher indicator stay on!
I have a problem with my left flasher indicator in my cluster. The indicator is always ON, on a half intensity when the headlights are ON and the indicator don`'t flash but the right one work well. I tried to change the circuit board with another that I had but it is the same result. What do you think?
'71 Custom/10 Deluxe LWB
'71 Custom/30 Deluxe Dually
syncrov69 is offline   Reply With Quote
Old 06-16-2012, 05:56 AM   #2
MikeyMan
Re: Cluster left flasher indicator stay on!
Probably a bad ground or connection. Make sure your bulbs are good too.
My left front turn signal sometimes does that. When my dash indicator lights up, I know the TS ain't right. I get out and wiggle the wires at the back of the socket and it comes back on and dash indicator goes out.
Mine is a 71, so the TS housings ground to the bumper. I've replaced the rusty screws with stainless.
MikeyMan is offline   Reply With Quote
Old 06-16-2012, 07:55 AM   #3
Todd Hepler
Rottenwood Garage Member
Todd Hepler's Avatar
2 possibilities come to mind:
1- Wrong bulb: a single element bulb in one of the lights will backfeed voltage from the parking circuit into the turn signal circuit causing the dash indicator to stay on and the flasher to not work. This is what I would check first.
2- Cardboard tube inside the cluster is loose or missing causing reflected light from the gauge cluster to shine through the indicator arrow. This doesn't explain why the blinker doesn't work though...
Good luck!
Todd
Todd Hepler is offline   Reply With Quote
Old 06-16-2012, 08:11 AM   #4
C5Phil
C5Phil's Avatar
I had same issue- after I re-assembled front end (during rebuild) it seems to have disappeared- leading me to think it was a bad ground--
C5Phil is offline   Reply With Quote
Old 06-16-2012, 08:26 AM   #5
syncrov69
syncrov69's Avatar
Good luck!
Todd
1-Ok I don't have bulb installed I just make a test in my cab with the cluster, the only working bulb is the dome lamp and the cluster bulbs.
2-The cardboard is ok and I have a delay (very light delay) between the backlight of the cluster and the left indicator!
Old 06-16-2012, 08:33 AM   #6
Todd Hepler
The bulbs I am referring to are the taillight or front signal bulb - They are two-element 1157's. You can jam a single element (1156?) in there and it'll light up, but the single contact bridges the parklight/turn signal contacts and feeds voltage from the park light circuit into the turn signal circuit, causing the dash indicator to stay on when the parking lights and/or headlights are on.
Its a quick and easy test and fix
-T
Old 06-16-2012, 11:36 AM   #7
ole dollor
ole dollor's Avatar
syncrov69: a bulb can also cross over inside itself, one elements can come loose from where it is connected, and touch to other element ,walk around your vehicle with all of your different lights on and see if they are the same. like park lights on,then rt turn, then left turn,then brakes lights, or you can remove one bulb at a time and see if this will turn off the dash light...if its one of the turn signal or brake light bulb it will light up the other lights also....a 1156 like tod helper said will cause problems also might check both ways....hope this helps...
ole dollor is offline   Reply With Quote
