Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-16-2012, 05:43 AM   #1
Spot1984
Hotchkis anti roll bar?
Does anyone have experience with a hotchkis antil roll bar? The one I'm looking at is part number tchkis #515-22390R. What I don't understand is why would you connect the rod end to the trailing arm? Wouldn't it be smarter to connect the roll bar to the frame and then from the frame to the axle tubes?
1970 Chevy C10 shortbox- 454
1970 Chevy Nova- 383
1987 Grand National
Spot1984 is offline   Reply With Quote
Old 06-16-2012, 10:08 AM   #2
djracer
djracer's Avatar
Re: Hotchkis anti roll bar?
The way you think it should be is correct. I have never heard of doing it the other way. I would think theirs would be too expensive anyway. Everything else they have is!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-16-2012, 03:25 PM   #3
Super73
Super73's Avatar
I just looked at their instructions: http://static.summitracing.com/globa...hss-22390r.pdf
Couple things I don't like about it:
It is only 3/4"
Mounted too far forward, and the leverage ratio will have a bigger affect on the torsion of the bar. I see this working about as good as a stock one.
Mind you, when I did my cheap home built one, it was in the factory location mounted to the control arms in front of the springs and the rod ends tied in to the frame, but it was made of 1 1/2" .180 wall CM tubing. It was noticeably better than the stocker at the track.
For over $400, I would pass. For a less money but a bit more work, this is what we put in mine when we did the back half. http://www.rjracecars.com/RJ-Pro-Ser...-Prodview.html
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-16-2012, 10:15 PM   #4
djracer
djracer's Avatar
I think that is the one I just put on my Drag Truck also.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 06-17-2012, 12:43 AM   #5
Super73
Super73's Avatar
Great minds think alike?
Old 06-17-2012, 01:21 PM   #6
djracer
djracer's Avatar
I hear Ya Brother!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
