06-16-2012, 08:51 AM | #1 |
spring rate
what lb rear coilover spring are you guys using on your ad trucks
06-16-2012, 09:23 AM | #2 |
Re: spring rate
I had a hard time getting an answer on that. I am starting with 250 pounds per inch on my 52 GMC. I am going to run a gas tank in back sooo we will see. I should have all the parts made in the next two weeks.
06-16-2012, 10:50 AM | #3 |
Re: spring rate
My shocks from Aldan/Flat-out just came, and looks like 450's for the rears. Unless they had a mix up. They were dropped shipped. I went with the 'recommendation.'
I've pinged Don at Flat-out for clarification just in case. I'll post back what I hear.
51 Chevy 3100 5 Window Build Thread: http://www.67-72chevytrucks.com/vboa...d.php?t=516689 |
06-16-2012, 03:23 PM | #4 |
Re: spring rate
wow 2 X 450 that's 900 pounds per inch! sounds stiff even for the front.
06-16-2012, 07:11 PM | #5 |
Re: spring rate
i was told to run 200 in my ad unless i was gonna haul somethin an if i was i was told to use 250
06-16-2012, 07:16 PM | #6 |
Re: spring rate
06-16-2012, 09:28 PM | #7 |
Re: spring rate
that sounds more like it! Then maybe I will be ok with the extra wieght of the gas tank behind the rear end.
06-17-2012, 12:37 AM | #8 |
Re: spring rate
Indeed, something seems 'off' Aldan's site lists much lower rates for street rods and such.
06-18-2012, 01:24 PM | #9 |
Re: spring rate
I am running 250 lb in the rear of a 59 with fleetside bed, steel floor and rear tank. They ride very nice. Not an AD but probably similar in weight
06-18-2012, 08:31 PM | #10 |
Re: spring rate
Thanks buggy.
