06-16-2012, 05:50 PM | #1 |
Trailing arms
Are the trailing arms on a SWB and a LWB different lenghts? I would think that they are, but just want someone to confirm it. I can't find any lenghts on them anywhere on the net. If it helps trailing arms are from a 67 C10.
Favorite quote: "I'm sick and tired of being sick and tired BĦħ@h!" - Drunk guy in one of my accounts Rides: 67 Chevy C10 LWB Stake Bed(in bad shape) 04 Miti Endeavor AWD(wife's ride) 76 Dodge D100 Club Cab(Hand-me down from my Grandfather) |
06-16-2012, 06:46 PM | #2 |
low n' slo
Re: Trailing arms
as far as i know they are the same length..
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
06-16-2012, 06:47 PM | #3 |
Moderator
Re: Trailing arms
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-16-2012, 06:55 PM | #4 |
Fun Stuff
Re: Trailing arms
The difference is that the cross member the arms are mounted to is farther forward on the swb. So if you are shortening a long bed, remove 12" of frame in front of the cross member.
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd |
06-16-2012, 08:28 PM | #5 |
Re: Trailing arms
I was thinking of moving the trailing arms from my C10 LWB to my GMC SWB frame. I'm not sure which way I want to go yet. If I do move them what is involved in the move?
06-17-2012, 02:12 AM | #6 |
Fun Stuff
Re: Trailing arms
I don't know if the GMC frame is the same as the Chevy, as far as spacing, but you would have to move the whole cross member as well as the spring, shock and panhard mounts. Good luck.
06-17-2012, 02:23 AM | #7 |
Re: Trailing arms
The frames are basically the same dimensionally. There are subtle differences between the leaf & coil frame set-ups but one suspension can easily be swapped over to the other.
