Shock question
Long story short - 72 blazer with 2 in tuff country ez ride springs up front, blocks in the rear. Ive got the correct 2 inch t.c. shocks up front, but stock length shocks in the rear.
I found an extra set of 2 inch front shocks and a set of 4 inch rear shocks (both t.c. Sx8000) in the garage - can I run either of these in the rear until I get some 4 inch springs to level it out? Posted via Mobile Device |
![]() Join Date: May 2007
Re: Shock question
The best way to find perfect fitting shocks, is to find some sort of ditch to drive into, at an angle. Do it so a front tire, and the opposite rear are both in the bottom of the ditch, and the other 2 are up on the banks. Preferably, a steep enough ditch that 1 wheel ends up off the ground. Do this with your shocks UNBOLTED. Now measure the compressed distance between your upper and lower shock mounts, and the extended distance on the other 2. Take these measurements, and look through a shock catalog. (skyjacker, for example) They will give the fully extended, and fully compressed shock measurements. Find the shock measurements that meet your needs. You don't want your shocks to ever be bottomed out, or over extended. If all of your driving is on the street, you will never reach either end of your shock. But if you ever venture off road, you will want a proper fitting shock. I have found that the shocks that come with kits, are not usually the ideal shocks for your specific application.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Re: Shock question
For what it's worth, this thread has pretty much convinced me to always go with Bilsteins over the shocks that come with lift kits.
http://www.expeditionportal.com/foru...-shocks-to-get
1954 Ford F-100 1956 Chevy big window 1970 4x4 Blazer CST 1987 Land Cruiser 1990 Chevy K3500 454 |
