Old 06-16-2012, 11:57 PM   #1
68short
68short's Avatar
Anyone cut a longbed to shortbed with a wood floor
I've read several longbed to shortbed with steel floor, and actually had good success doing the conversion with a steel floor, but I cant seem to find a thread on a wood floor. Im curious if the process is different because of the different cross sill's, and bolting pattern
Any help appreciated
68short is offline   Reply With Quote
Old 06-17-2012, 03:58 AM   #2
SS Tim
SS Tim's Avatar
Re: Anyone cut a longbed to shortbed with a wood floor
Like to see a thread on wood fleetside mods. myself. These links have a lot of wood bed info. I'd imagine that once the sides were reduced down to the 6.5' it should assemble up with new strips/wood just like a factory bed.
http://www.mar-k.com/installation_hints.aspx
http://www.gmcpauls.com/47-72_BedWood_Info.htm
SS Tim is offline   Reply With Quote
Old 06-17-2012, 08:01 AM   #3
I'm building a shortbed using short bedside and long floor supports. I just have more supports than I need. The wood and bed strips will be new shortbed stuff. If you're wondering about using longbed wood and strips,the holes will be in the wrong places.
Old 06-17-2012, 09:55 AM   #4
hugger6933
I have a wood floor bed that I planed to put on short sides and use all but one cross sill and get new strips and wood for a short bed. That was my plan but the last truck I had come in has the nicest steel floor I have seen in some time [on just a cheap regular truck,not a showpiece]
hugger6933 is offline   Reply With Quote
Old 06-17-2012, 10:13 AM   #5
68short
68short's Avatar
Nah, the wood & strips are toast. More interested if the cut pattern would change so the supports wood line up for the new wood/strips. Honestly I haven't even visually compared the metal versus wood floor supports. I found a wood longbed with beautiful sides, and contemplating whether I should pick it up today
Old 06-17-2012, 10:37 AM   #6
71swb4x4
71swb4x4's Avatar
Another problem you will have is the body line on the long bed. It will take some good metal work to make the body line "correct".
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-17-2012, 11:10 AM   #7
68short
68short's Avatar
I didn't have a problem doing the cut on this steel bed, it lined up fine
Old 06-17-2012, 11:35 AM   #8
71swb4x4
71swb4x4's Avatar
You didn't have to work the rear? It starts high and sweeps down. I don't need to tell you that, you have done it. Was there an easy fix to get it to line up?
Old 06-17-2012, 11:42 AM   #9
68short
68short's Avatar
Very minor feathering at the top, maybe an hour for both sides
Add: used a stud welder
