Old 06-17-2012, 11:01 AM   #1
dfarr67
88-98 CK1500 10 bolt Rear Disc Conversion
Hi,
I have a 1989 K1500, 8.5in corp 10 bolt, from factory the brakes were garbage and I have since put the 2500 front calipers on up front, hydroboost, and years ago a rear disc conversion- this kit takes 1988 light duty front rotors and the D154 GM caliper, cheap and from many years of cars, currently using 1994 S10 calipers. I never could get Eldorado calipers to work properly so I have a transfer case mounted driveline safety brake. Anyway, from day one the pass side wasn't square, I suppose since the bracket is a two piece welded unit- the welding may have warped it- I don't know, I do know that the pads wear into wedges- sure I could take a sledge to it.....
So I've been looking around and have seen some high dollar kits and ran across John here and his kits look to be high quality, BUT he only makes them for 67-87 GM trucks, as per his email below I'm looking for some interest in a reasonably price kit- I've also been looking at Wilwood D154 replacements and dual piston calipers, aluminum and SS pistons- not a bad price too, but I have in mind 98-04 S10 front dual piston caliper, should be easy to find cheap and powerful, see what he comes up with. At this time, any caliper with a integral parking brake would probably too light for a truck app.
Here's a sample of his work- you can check out his other products.
D52 Caliper Rear Disc Brake Brackets - The 1947 - Present Chevrolet & GMC Truck Message Board Network
Hello Dave
I would be willing to develop something for the '88-'98 differentials if there was enough solid interest. However I would not be able to do anything on this for about 6 weeks. I have just entirely too much work right now. If I could get 4 or 5 commitments on rear disc brake brackets that would be sufficient for me to put the time into development.
John
John Wastweet captainfab454@hotmail.com
dfarr67 is offline   Reply With Quote
Old 06-17-2012, 01:52 PM   #2
Dobok
Re: 88-98 CK1500 10 bolt Rear Disc Conversion
I have a 91 chevy with a 10 bolt rear and have been thinking about rear discs brakes for a while,So I am interested to see what he could come up with !!! I am sure there is more interest too !!!
Dobok is offline   Reply With Quote
Old 06-17-2012, 05:39 PM   #3
G&R's57GMC
G&R's57GMC's Avatar
Mr Rich posted this pic of his rear brake on his stock '89 1500 Tahoe. Its a Factory option.
It appears to have an internal drum parking brake in the hat of the disc rotor.
This could be the easy way to get rear disc brakes, its all bolt on. Call some wrecking yards and get everything from the P/B cables to the caliper.
G&R's57GMC is offline   Reply With Quote
Old 06-17-2012, 10:29 PM   #4
dfarr67
I guess nobody ticked that particular box around here, that style of chev is rare enough at the yards (here) and I've never seen a stock rear disk except on the 99+.
Old 06-17-2012, 11:24 PM   #5
Captainfab
60-66 Nut
Do you have a link to a thread on Mr Rich's Tahoe? Not to argue, but that just doesn't look like a factory rear disc I am used to seeing.
Old 06-18-2012, 12:07 AM   #6
G&R's57GMC
G&R's57GMC's Avatar
Here's the link http://67-72chevytrucks.com/vboard/s...d.php?t=529751
Old 06-18-2012, 01:34 AM   #7
G&R's57GMC
G&R's57GMC's Avatar
Looking again at Mr Rich's rear brake does make me wonder if its stock.
Ha, I just looked at his sig. and its a Stillen Rear disc conversion kit.
BTW It's a '89 K1500 extended cab not a Tahoe.
Old 06-18-2012, 01:43 AM   #8
G&R's57GMC
G&R's57GMC's Avatar
Here's a link to the Stillen kits
http://www.stillen.com/product.asp?i...NV1&c=BR&m=all
Old 06-18-2012, 10:49 AM   #9
dfarr67
$$$$$$$$1400
Old 06-18-2012, 06:15 PM   #10
greystoke
I have a 93 2wd and would be interested in a decent priced setup. There's a reason we call this guy Captain Fab
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline   Reply With Quote
Old 06-18-2012, 11:26 PM   #11
jerrymp
Well, here are some links for you
http://www.fullsizechevy.com/forum/g...-question.html
http://www.fullsizechevy.com/forum/g...-97-c1500.html
http://coloradok5.com/atrondiskbrakes.shtml
http://www.fullsizechevy.com/forum/g...r-10-bolt.html
Pay attention to the info about the proportioning valve. Its important.
Post back when you are done with pics and such.
jerrymp is offline   Reply With Quote
Old 06-19-2012, 09:56 AM   #12
dfarr67
I have a functioning disk conversion:
- stock master cyl
- combi valve off 2000 chev picku
- hydroboost
-- my problem is a defective bracket that is not true causing pad wear issues
-- using D154 callipers- while cheap, I think there are better oe callipers out there now
Old 06-19-2012, 05:17 PM   #13
Mr_Rich
Mr_Rich's Avatar
I'm baa-a-ck. While the Stillen kit is very expensive, it is the best engineered disk brake conversion kit out there. There are other kits that are very good, but you give up the emergency brake, for example. I tried the SS kit and decided not to use it and sold it on E-bay a while back. The Baer kit is NOT bolt-on and requires machining of the axles. It would be nice to have off-the-shelf factory parts WITH an emergency brake to bolt on to the older axles, but it doesn't seem those parts exist.
Modifying the spring pads and shock mounts on a late model diff. might be the best solution to get off-the-shelf factory parts on a disk brake rear diff. to fit a classic Chev. truck/ Sub/ Tahoe.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E (sold)
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 06-19-2012, 08:23 PM   #14
dfarr67
Yeah- if I knew then what I know now.....
I would have purchased the '99 up diff and installed that, my issue now is that I have a TruTrac installed and also when I was having it installed with gears (for the 3rd time- just pay for the expertise up front instead of cheaping out) the installer commented that the later model diff's weren't as stiff and tended to sag- he would put a laser end to end and press it straight.
Old 06-20-2012, 08:31 AM   #15
stevejohnson48
Originally Posted by dfarr67 View Post
Hi,
Hello Dave
John
///// I might be interested in a rear dics set up for my 90 Z71, Ive been wanting to change over for some time ,( pulling capabilities)because of the brake fade,but the parts to convert are at a cost beyond budget, TSM.or was it TMS, I believe there out of Colorado, was the close's price match when I was looking ,but it was still to expensive , so shoot me a price , and component configuration when you get around to it, 10 bolt 6 bolt corporation,(not the HD44!!)
stevejohnson48 is offline   Reply With Quote
Old 06-23-2012, 11:58 AM   #16
dfarr67
Yes, I have been trying to keep up on the thread you started. It will still be a few weeks before I can do much on this, but the wheels are turning. I am going to try and incorporate an e-brake into this assembly as well as a more modern caliper as opposed to the D154.
John
Old 06-23-2012, 12:10 PM   #17
Dobok
I;m in !!! 5 bolt !!! 91 !!!! All the conversions must be made of gold or have diamonds in them;Way too pricey---
Old 07-07-2012, 10:56 AM   #18
Grimee
Grimee's Avatar
Here is a pic of a Baer conversion its on my 2 door 2 wd tahoe it has the factory drum style e brake built in
Grimee is offline   Reply With Quote
Old 07-07-2012, 12:04 PM   #19
Mr_Rich
Mr_Rich's Avatar
Now THAT looks expensive! Beautiful setup though...
1989 K1500 Chev. EC
Old 07-18-2012, 02:05 PM   #20
dfarr67
Any headway on this?
Old 07-18-2012, 11:50 PM   #21
Captainfab
60-66 Nut
Not much really....still working 70-80 hrs a week. I've got an idea for the e-brake. I'm hoping for some time in about another week.
Old 07-19-2012, 08:32 PM   #22
jb1016
"Oh well, it's a driver."
jb1016's Avatar
subbed for this...wanna see how this goes
Old 08-13-2012, 10:02 PM   #23
derek6787
Backwoods Body
I am also interested in these. I spent alot of time trying to figure out a way to make this work with all stock parts but couldn't find any '94 Impala SS brackets. But I did figure out that you could use the Impala SS rotors and Camaro calipers. The Camaro calipers are used because they actually use the main pads for ebrake instead of an internal drum like the Impala. You can find as cheap of calipers or as good of calipers as you want for the camaro as well. Same goes for the pads. Just my $.02 but very interested in these brackets. (93 gmc 2wd 5 lug 10 bolt)
derek6787 is offline   Reply With Quote
Old 08-15-2012, 05:36 AM   #24
rchavez101
rchavez101's Avatar
Interested.
94 Chevy SWB in progress.
http://67-72chevytrucks.com/vboard/s...d.php?t=477390
rchavez101 is offline   Reply With Quote
Old 08-19-2012, 10:16 PM   #25
bigmone
I have a 90 silverado 2wd I want rear discs I'm all in plus any front upgrades too
bigmone is offline   Reply With Quote
