Inline 6 250 with a 4 barell what brake booster will fit?
Im trying to put my power brakes in my truck but the booster hits the carb. What are you guys using for a booster that clears the carb and air cleaner?
Posted via Mobile Device |
Re: Inline 6 250 with a 4 barell what brake booster will fit?
I know of one that Might help, the one off of a mid 80's trans am or camaro, they are not as large in diameter, but it is a little longer, I am working on restoring a 1984 trans am ws6, it has the upgraded breaks, one like it has might be a good one to try.
![]() Join Date: Oct 2006
If you have power steering, put on hydroboost
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
#4 | |
Manimal, I was actually thinking of doing that but I would honestly prefer the normal booster or just stick to manual brakes. How bad is it going to be running a power brake master with manual brakes? Posted via Mobile Device |
the master bolt pattern is a universal standard, Yes it will bold up, as far as the measurements I am not sure, I have not measured it I can tell by looking it is has a Much smaller diameter. it is easy to see there is a big difference between the two. I hope this helps.
Ok man, Thanks for the info. I think I am going to put a smaller carb on it. After I do that I'll give that booster a shot.
I found a good pic on ebay for you, this is what it looks like
http://www.ebay.com/itm/FIREBIRD-TA-...-/360095745105 |
Right on man, looks a lot smaller then mine. I wonder if I would have to use the brackets from that one or if my brackets and linkages would work with it.
425hp409
![]() Join Date: Oct 2008
I installed a stock booster in a 70 truck with a 6 cylinder one barrel and it cleared the carb fine, but I had to use a small aftermarket air cleaner. Remember, a 3/4 ton booster is thicker that one for a 1/2 ton.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
