06-17-2012, 03:58 PM | #1 |
emblem stud repair
Has anyone repaired studs on emblems or know if even possible? I have a nice pair gmc custom fender emblems with broken studs and thought maybe someone else might have had same problem and repaired it
06-17-2012, 04:02 PM | #2 |
#16876
Re: emblem stud repair
You may have to explore adhesives. Maybe try a push nut if there is enough stud left.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
06-17-2012, 04:25 PM | #3 |
CAN'T FIX NOTHIN
grind the old studs off smooth with a die grinder then jb weld some small bolts from any hardware store in their place then after it hardens you can install the emblems and put nut's on from the back
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
06-17-2012, 04:31 PM | #4 |
have never used jb weld, does it hold up well, sounds like a good idea, thanks
06-17-2012, 04:42 PM | #5 |
CAN'T FIX NOTHIN
yep works like a charm !
06-17-2012, 04:55 PM | #6 |
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
06-17-2012, 05:26 PM | #7 |
You can also grind them smooth, add a glob of the jb weld. After it has dried, drill and tap it so that you can screw your bolt into it from the back side. The stuff works great.
1969 4x4 Nothing beats a good rock drill and some dynamite |
06-17-2012, 06:46 PM | #8 |
I just did the JB-Weld trick today on my 68 front Grill Bowtie...
It worked perfectly... and now I have a "real" nut to work with as well Give it a shot, it was super simple and effective!
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi, My 68-SWB Photo Build Thread All my Google Albums |
06-17-2012, 11:41 PM | #9 |
Great info ...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
