Old 06-17-2012, 07:24 PM   #1
zirk
zirk's Avatar
Repairing Rust
I'm looking to fix some rust on my truck, is it better to completely replace the rusted area with sheet metal or would bondo do the trick?
Chevy runs in my blood
zirk is offline   Reply With Quote
Old 06-17-2012, 07:51 PM   #2
Zane M
Re: Repairing Rust
Bondo will not do the trick unless you are going for ghetto repair.
Zane M is offline   Reply With Quote
Old 06-17-2012, 07:54 PM   #3
Nin92
Nin92's Avatar
Re: Repairing Rust
If you are looking to actually "Fix" the rust, I would replace the sheet metal. If you are looking to hide the rust, then bondo will do the trick. Patching the takes a heck of a lot more time but I think its worth it in the long run.
Nin92 is offline   Reply With Quote
Old 06-17-2012, 08:01 PM   #4
zirk
zirk's Avatar
Re: Repairing Rust
Thanks man! I figured replacing the metal would be best.
Old 06-17-2012, 08:01 PM   #5
bigwheel15
bigwheel15's Avatar
Re: Repairing Rust
If you want to fix it, cutting out and welding in new metal is your only option, sure you can bondo over the rust but that is nothing more than covering the problem. I can guarantee you that you will see that rust creep back shortly and now you're back to square one.
So to simply state; do it once, do it right and be done with it.
bigwheel15 is offline   Reply With Quote
Old 06-17-2012, 08:03 PM   #6
zirk
zirk's Avatar
Re: Repairing Rust
Old 06-17-2012, 09:54 PM   #7
Weasel Diesel
Re: Repairing Rust
Always think of rust as Cancer. You can cut it out and get a pretty good life, or you can take an asprin and pray, but it will return.
Weasel Diesel is offline   Reply With Quote
Old 06-18-2012, 03:33 AM   #8
andrewmp6
Re: Repairing Rust
Body filler is not a hole filler it will pop out later on,The right way is cut out the rust and weld in new metal.But the other option if you can't weld is panel adhesive most body shops use it on sheet metal it holds pretty good.But just don't use it on something like the frame.
andrewmp6 is offline   Reply With Quote
Old 06-18-2012, 07:08 AM   #9
Your41Plague12
Your41Plague12's Avatar
Re: Repairing Rust
Panel adhesive works pretty well, but you will notice it starting to get funky if it sits in the sun for long periods of time over a period of like 10 years. It's still quicker than a weld and there's no worry about warping anything.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
