Old 06-17-2012, 10:14 PM   #1
mopar346
Square body Regular cab roll back question
I am fixin to buy an 88 (classic body style) regular cab 3500 flat bed and am considering making it a roll back. It has 155 inch wheel base and has 11 feet of frame behind the cab. My question is for anyone who has a square body regular cab roll back or good knowledge of one.
What is your wheelbase?
How much frame do you have after the cab?
What size roll back bed do you have?
Thanks in advance, Kevin
mopar346 is offline   Reply With Quote
Old 06-17-2012, 10:26 PM   #2
86c20
86c20's Avatar
Re: Square body Regular cab roll back question
i have a 78-85ish one it is a real mutt has some 4wd parts and an 85 front clip with 80 cab and what i think is a 78 jarrydan deck. deck is 17.5feet not sure on the wheel base can find out if you need. my leafs are a home made 14 stack with a 4 pack over load. if i would have to guess there is about 10 feet plus of frame behind that cab(it turns like crap). let me no what you need and i will get it for you. later, mike
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 06-17-2012, 10:37 PM   #3
mopar346
Thanks Mike, the measurements would be great, I have access to a 17 foot aluminum bed, not sure what make. A wrecker friend of mine siad that 11 ft is not enough frame behind the cab for it but it sure looks like it would be enough to me. I am picking it up for $1200 and I figure I'll get half that back in scrap when I pull the current flatbed and take it to the bone yard. The cab has zero rust, even the hood is perfect with no folds at the hinges. I only have 2 concerns with it, the first is it has a 350 but with 4.56s it should be fine in town and moderate distances. The second is it was/is no A/C from the factory, which can be solved with vintage air or get a complete factory set up from the bone yard. It has a turbo 400 which should be fine but I could convert it if need to a 7004R.
By the way, I am building this for personal use only.
Old 06-17-2012, 10:51 PM   #4
Zane M
No advice/experience to offer other than do not ditch the 400 in favor of the 700R4. For a Hauler, the 400 is a better transmission.
Zane M is offline   Reply With Quote
Old 06-17-2012, 11:19 PM   #5
mopar346
I agree it's better but the OD might be nice if I decide to use it for serious distances. I think the first gear is lower in a 700 as well. I don't play with GMs that much so my memory is foggy. I have a friend who can build one that will hold up to anything, but reality is I am a cheap bastage so I wont change it if it don't give me a reason.
Old 06-18-2012, 12:32 AM   #6
Zane M
If you are going to use it for serious distances empty, sure, no issue. But if you are going to be hauling/towing serious distances, the 400 is still going to be better as you can't/shouldn't be using the OD in that situation anyway.
Old 06-18-2012, 08:51 AM   #7
mopar346
Good point. I current do use my OD in certain situations when towing with a trailer, but like I said unless it gives me reason I'm not doing anything with the tranny.
Old 06-21-2012, 10:20 PM   #8
mopar346
86c20, did you get a chance to get any measurements?
Anyone else have any input?
