Old 06-18-2012, 09:44 AM   #1
blackdawg
Blackdawg
Anbody have pictures of the stock e brake setup
my ebrake was removed when i bought the truck.want to make sure i have the proper bracket and support for the steering.any pictures would be helpful.just bought another stock ebrake and the cable is running up the column.the rear cable to the back drums are seized and need to be replaced.
the rest seems to be there and useable.
LIFE NEEDS NO RED LIGHTS !!
1966 chevy stepside. Aka Bella.
1998 chevy s-10 4x4 daily driver.
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=467164
blackdawg is offline   Reply With Quote
Old 06-18-2012, 02:37 PM   #2
70cst
70cst's Avatar
Re: Anbody have pictures of the stock e brake setup
TTT
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-19-2012, 09:35 AM   #3
blackdawg
Blackdawg
Anybody have a picture under the dash ?
Old 06-19-2012, 09:50 AM   #4
doobiebro
doobiebro's Avatar
What year is your truck? You just need pics of the park brake lever and mounting right...
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 06-19-2012, 01:28 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Perhaps these images from the 1960 Chevy Truck Shop manual will help:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-19-2012, 03:08 PM   #6
losthope
losthope's Avatar
I dont know if years are different or not but i assume you have a 66 by looking at your profile so i went out and took some pictures of my 66, If i didnt get what you need let me know and i can try and take more pictures for you:
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 06-19-2012, 05:51 PM   #7
losthope
losthope's Avatar
Tried to get some of the pictures of the bracket that mounts around the column for you!
this is looking from the drivers door up theres two bolts that mount it:
heres looking up at where it mounts on the column has two bolts:
heres the part that is bent around the brake light switch:
and this is one is looking up from the passanger side where it mounts with two bolts:
once again hope this helps
Timmy D.
Old 06-20-2012, 09:43 AM   #8
blackdawg
Blackdawg
yes it is for a 1966 chevy.any pictures underneath where the ebrake is located is appreciated.thanks John
Old 06-20-2012, 12:16 PM   #9
CRGRS 66
CRGRS 66's Avatar
I just put a bunch of pictures up last night for jsdoyle have a look
http://67-72chevytrucks.com/vboard/s...d.php?t=530055
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 06-20-2012, 12:17 PM   #10
CRGRS 66
CRGRS 66's Avatar
Mine is original, if you need more pictures, let me know, the rear is still up on the ramps
The shop manual shows everything as well, good investment if you don't own one.
Craigerrr
Old 06-20-2012, 12:45 PM   #11
losthope
losthope's Avatar
Heres is the 1966 brake section of "woogeroo"'s web page,great pictures of the routing cables under the truck but just the frame so you might get a better idea with the cab and bed off:
http://houseofwoogeroo.wordpress.com.../brakessettwo/
Timmy D.
Old 06-23-2012, 11:47 AM   #12
blackdawg
Blackdawg
excellent thanks guys that was a great help.previous pm removed the ebrake handle.bracket still is the but it is mickey mouse.trying to locate a ebrake handle and bracket.the cable is running up the steering column.and then have to replace rear brake cables to the drums.there were seized.the rest seems to be there.
