06-18-2012, 11:15 AM | #1 |
Sad day.....
Well about a week or so ago i blew a head gasket in my burban.....Im going to have to push it in the back yard till i have the funds to rebuild the motor i hope its not to bad in there.......
{List of Toys} 2005 Nissan Frontier Nismo Edition 1972 Monte Carlo 1971 Chevy Suburban |
06-18-2012, 02:36 PM | #2 |
Re: Sad day.....
Not cool man. With this heat it put a load on us. Hope it all works out for you.
----------------------------------------------------------- Erik My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626 1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647 RUST!? Thats just mother natures way of telling all of us.....MINE!!!! |
06-18-2012, 03:10 PM | #3 |
The Older Generation
Re: Sad day.....
You may just need the head gasket right now. If it leaked antifreeze into the pan and and it circulated through the engine you will need a lot more than that later, if you let it set too long. Just my 2¢ worth LockDoc
06-18-2012, 09:08 PM | #4 |
What?
Re: Sad day.....
If you can't touch it for a while, I would drain the coolant and oil.
Blow some air into the heater pipe to blow out all sitting coolant, pull all the spark plugs and then turn the engine over a couple times to blow out any coolant that could be in one or more of the cylinders. Once that's done, spray a bunch of WD-40 into each spark plug hole. Finally put a note on your dash warning you that there is no oil/coolant in your engine, since the truck will be sitting for a while you don't want to forget and fire it up with nothing in it. This is what I would do, since standing water in the cylinder will rust and cause damage to the cylinder wall and rings. Plus if there is coolant in the pan, you want to get it out and not let condensation build up causing more problems.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
