06-18-2012, 02:06 PM | #1 |
cummins crossmember
does anyone know where i can get a crossmember for a chevy cummins conversion. avalanche engineering is out of business, screamin seeman wont call back, tennessee diesel conversion doesnt have the set-up. am i out of options or is there someone else. iknow everyone will say build one but i would rather buy one from someone who has built alot of them and have tested them too.
06-18-2012, 09:42 PM | #2 |
Re: cummins crossmember
I got mine form tennesse diesel. I used this one http://www.tndieselpower.com/site/pr...ember-package/
Clint Youse Paris, MO 1984 Chevrolet 3+3 K30 with Cummins 1966 IH Scout has been a work in progress for 16 yrs |
06-19-2012, 02:03 AM | #3 |
http://www.autoworldmt.com/Page_11.html has one you have to email them for a price tho.
06-19-2012, 03:20 AM | #4 |
what do you mean TN diesel doesn't have the setup? Scott should have them in stock.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
06-19-2012, 11:43 AM | #5 |
i am converting a 2wd to 4x4. tenn diesel is used in a 4x4 frame. i dont have anything but the frame. no crossmember no engine mounts nothing, i have to have a complete cossmember and mount assy.
AUTO WORLD is CRAZY expensive, just the mounts are 500.00 and the crossmember is 650.00. |
06-19-2012, 09:52 PM | #6 |
take your 2wd mounts, and box the bottom of them so they bolt to the frame down there, and then use some 1.5 square tube to make a crossmember between the frame. works great. I just turned a 2wd frame into a 4wd one for my truck after I wrecked it. my 1.5 crossmember was unhurt. shouldn't take more than a weekend. you can buy just the engine mounts from tn diesel, and then you're golden. mine are a copy of his mounts, and uses the stock chevy mounts.
06-19-2012, 09:53 PM | #7 |
oops just realized you don't even have the 2wd mounts. should be easy enough to junkyard a pair of them though.
