Old 06-18-2012, 02:14 PM   #1
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
68 C10 Binding Issue 5.5/7.5 drop, help please
the attached pics from my build thread show the binding on the driver side and the passenger side looks the same in the pic but has no issues, the steering box is a power one from a 70 and from my reading shouldn't be a problem, I can get more pics if needed but I'm unsure what I did wrong here, thanks for any input
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 06-18-2012, 03:18 PM   #2
SCOTI
SCOTI's Avatar
Re: 68 C10 Binding Issue 5.5/7.5 drop, help please
Binding usually means the drag/center link is instaled incorrectly. Try flipping it's position.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-18-2012, 03:44 PM   #3
tantrumpipeline
will do thanks
20 Duramax tow pig
52 short project
Old 06-18-2012, 07:38 PM   #4
tantrumpipeline
looked for pics online and it seems to be correct? the ends are tapered so I can't see how it can be any different, possiblky the pitman arm needs to be tightened more but it's really binding at this point? heres a few more pics, blurry but give the point and more angles
20 Duramax tow pig
52 short project
Old 06-18-2012, 07:52 PM   #5
SCOTI
SCOTI's Avatar
That centerlink looks like it's bent to me in those pics. Is it one you utilized before the drop?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-18-2012, 07:56 PM   #6
robnolimit
robnolimit's Avatar
Could just be me, but I've never seen a center link with a big sexy bend in it like that one. You may need to get a straight one.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 06-18-2012, 10:19 PM   #7
tantrumpipeline
Sweet deal it was on the truck when I purchased it and it was drivable but it was pre lift, I'll source a used one thanks for the help
20 Duramax tow pig
52 short project
Old 06-18-2012, 11:07 PM   #8
tantrumpipeline
Pre drop I meant, usually my trucks go the other way
20 Duramax tow pig
52 short project
