Need help locating this!
This cross member / brace's is from a 1987 chevy two wheel drive, it's located at the very front between the frame rail's, it was badly bent / cracked and I tried to straighten it, but I am not happy with it. The only one I could find locally from a junk yard was perfect until they distoryed it when they removed it! So I am out of OPTIONS locally and was just wondering if someone knew of a good place to locate one? Thanks!
Re: Need help locating this!
They may have one at a yard in Joliet,IL. But I don't know how much they will wont.
well close to you i would go to PH AZ and go to there junk yards
wouldnt one from a the older square work all they did is remove some weight by cutting out the holes the older one won't crack
Agree.
I don't think it carries a lot of load, since most of the weight goes through the front suspension crossmember. The front bumper also helps to tie the front of the frame together. So - if you can straighten this one up enough to be "beautiful" then I think it will be sufficient. It just needs to hold up the proportioning valve and some brake line clips and that's about it. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Thanks for the reply's, I think I will try one more time to make it work! I thought this would be very simple to straight out and make it look descent, I was wrong, the curved part is kicking my butt! Maybe I was just looking for the easy way out!
