Old 06-19-2012, 12:15 AM   #1
matts86chev
matts86chev's Avatar
Talking Holy SHooT.
So this is my first post in awhile but I feel like the title is fitting. It's probably my own fault for letting things pile up and compound but hey I work 40+ hours a week and go to school full time... Anyways So here goes my list of help me pleases:
Main thing, which probably isn't really an issue but still good to hear of other people having similar experiences. Today it was hot and humid and my truck decided to vapor lock right as i got onto the freeway. It got started again after waiting a few hours but I still am wondering if there's a way to avoid that. It Has only done it twice in the past 2 years but still a major PITA when it happens. Also, when I made it home I opened the hood and it was smoking off the left side. No clue what from. Wasn't overheating though.
Second. All my headlights stopped working. On the wiring diagram the headlights and the high beam indicator are on the same circuit and that also doesnt work. A few days before the high beam switch got stuck on. I suck at electronics and have no idea where to start...
Lastly, my temperature gauge doesn't work anymore. This one seems like the easiest I'm pretty sure it's just a bad ground or loose wire but I might as well nag about it here.
So if anyone feels like helpin a guy out shoot all the advice you got at me!
1986 Chevy C10 305 5.0L Work in progress...
matts86chev is offline   Reply With Quote
Old 06-19-2012, 03:07 AM   #2
andrewmp6
Re: Holy SH*T.
A carb spacer helps a lot with vapor lock.
andrewmp6 is offline   Reply With Quote
Old 06-19-2012, 12:00 PM   #3
deth_1970
deth_1970's Avatar
Re: Holy SH*T.
heatsinks on the metal line going to the carb, ziptie some long magnets to it,
78 dualy crew cab wife calls "the beast"
79 silverado "yeller"
99 tahoe
02 Gmc sierra
deth_1970 is offline   Reply With Quote
Old 06-19-2012, 12:47 PM   #4
Adams74Chevy
Adams74Chevy's Avatar
Re: Holy SHooT.
A little oil leaking from the valve cover onto the exhaust manifold?
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 06-19-2012, 04:45 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Holy SHooT.
please dont circumvent our language filters... if you need to put an asterisk (*) in place of a letter you shouldnt be using the word here... first and final warning this is a family friendly site
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 06-20-2012, 06:59 AM   #6
matts86chev
Re: Holy SHooT.
So I have heard. I think part of my problem is the previous owner put the fuel line in an odd spot and kinked it so it doesn't take much to lock it up. Its running now that it's cooler but it's running rough. I don't know if the fuel pump is going, the fuel line is screwed or the carb needs adjusting. I should probably get a new carb and spacer and start using non-oxygenated gas. My real headache right now is the headlights. I changed the switch behind the pull knob and they still don't work. Running lights, brake lights, interior lights all work but the hi/low indicator and switch dont seem to work and the headlights don't turn on. Can't find a fuse for them.
Old 06-20-2012, 07:02 AM   #7
matts86chev
Re: Holy SHooT.
Sorry, didn't mean to circumvent any filters. I've been spending too much time on chopcult and bike sites! Won't happen again.
Old 06-20-2012, 07:09 AM   #8
Sabaka454
Sabaka454's Avatar
Re: Holy SHooT.
Why do you think it's vapor lock? Make sure you have no kinked fuel lines and they're routed away from heat source.
Sabaka454 is offline   Reply With Quote
Old 06-20-2012, 07:45 AM   #9
matts86chev
Re: Holy SHooT.
I assume it is vapor lock because the past two day it has happened not days were 94+ degrees with insane humidity and it happened after sitting at long red lights. The line going into the fuel filter/carb looks linked so I think that is part of the problem but the fuel line goes right up the front of the engine and I don't know how I can do anything about that other than insulate it somehow.
Old 06-20-2012, 09:22 AM   #10
andrewmp6
Re: Holy SHooT.
I would try fixing that fuel line if its in the wrong place and kinked it could starve for fuel,And its probably closer to the engine so its getting hot in the line which isn't good either.Can someone post a picture of the stock fuel line to the carb so he has something to go by.
Old 06-20-2012, 10:38 AM   #11
matts86chev
Re: Holy SHooT.
Yeah a guy at work said he used to have trouble with his like that before he sold it and told me to replace it with rubber fuel line and route it a little further from the heat so I'm going to try that and see what happens.
