Old 06-19-2012, 01:52 AM   #1
MikeJones16
MikeJones16's Avatar
Brake switch location under dash? 79 silverado
Just wondering where the brakek light switch is located under my dash. Theres seems to be 2 connectors that kind of look like they have something to do with it..
I bought an EZ wiring kit and all it says is brake light on the wire. so i'm lost because on the connector there seems to be 2 wires.....
Please help I need this done by the end of tomorrow.
Thank you everyone.
MikeJones16 is offline   Reply With Quote
Old 06-19-2012, 03:19 PM   #2
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: Brake switch location under dash? 79 silverado
It should be down the passenger side of your column. It looks like a threaded end pushed through a hole in a bracket where your brake 'arm' pushed against the round switch in the end of it.
Its the third pic in post #16 on my old thread here:
http://67-72chevytrucks.com/vboard/s...d.php?t=507223
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 06-19-2012, 07:50 PM   #3
MikeJones16
Thanks! But there are two wires. I have one wire in my kit that says brake lights. Is that switch have a power wire and then the brake light wire at the other one?
Old 06-19-2012, 08:17 PM   #4
J Knight
J Knight's Avatar
Brake lights have a constant hot lead to the switch. If one isnt supplied in your kit Im sure you could run one from the fuse panel.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
