Old 06-19-2012, 09:56 AM   #1
Jayschevy
What part is this?
Whats the part called that is plugged into the transmission and your speedo cable connects to it? Mine is leaking transmission fluid and need to be replaced.
Jayschevy is offline   Reply With Quote
Old 06-19-2012, 10:55 AM   #2
DT1
DT1's Avatar
Re: What part is this?
I think it's called a speedometer gear housing. If it's leaking, it probably needs a new o-ring.
DT1 is offline   Reply With Quote
Old 06-20-2012, 06:21 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Could be a speedometer gear reducer.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 06-20-2012, 07:00 AM   #4
E.Furgal
thats outside the trans and "it" wouldn't be leaking...
E.Furgal is offline   Reply With Quote
Old 06-20-2012, 07:05 AM   #5
E.Furgal
o/p the part leaking this?
if so there are two o rings one on the speedo gear inside this part and one that goes
on this piece where it meets the transmission case
hope this helps
Old 06-20-2012, 07:07 AM   #6
If it has the reducer,those attatch "to" the transmission and "could" leak there. They go between the end of the speedometer cable (that attaches "to" the transmission) and the transmission. Same thing,prolly needs a new o-ring.
Old 06-20-2012, 07:14 AM   #7
E.Furgal
it not leak, the leak would be upsteam.. in the part shown
and be flowing through the reducer and cable
