Old 06-19-2012, 01:36 PM   #1
UATahoe
Need help on gauge cluster
Guys, need a little help here. I am looking for a new gauge cluster backing pate. Basically the whole assembly that the gauges attach to. I have found the part in the LMC catalogue (38-8100) but it says it will work for trucks that do not have the factory clock in the lower left corner. Well you guessed it, i do. Is there really any reason it wont work? I am ok with drilling a hole if i have to to make it work. Any help?
UATahoe is offline   Reply With Quote
Old 06-19-2012, 03:14 PM   #2
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: Need help on gauge cluster
I think it will work. You might have to drill a hole for the clock power wire and ground to go through but that isn't major.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 06-19-2012, 03:17 PM   #3
UATahoe
Thats what i was hoping. Sounds like it should be an easy fix. Thanks for the feedback!
Old 06-19-2012, 03:20 PM   #4
carboncrew
carboncrew's Avatar
you will have to remove some of the gauge/dummy light support as well. Dremel makes pretty easy work of that.
carboncrew is offline   Reply With Quote
