06-19-2012, 02:20 PM | #1 |
shortening the steering column
After reading the FAQs about this,can this be done to a column shift truck? A 3ott to be specific. If I have to install a floor shift I can. But can I still shorten the column? Im over 6 ft tall but prolly 7ft around the middle. My bathroom scales wont give a number,just this, one at a time,please. Thanks in advance. Muley
06-19-2012, 07:56 PM | #2 |
Re: shortening the steering column
been wanting to do that two....planning going to an auto trans, and want the steering wheel closer to the dash.....maybe some will chime in....mine is a floor shift 4 speed now...
06-19-2012, 08:50 PM | #3 |
I found this tilt colum in a van/rv it was a dash shifted rv. there for it has no shift leaver at the bottom or top it is 4" shorter than a truck colum witch should eliminate the shaft space between the colum cup and dash.I got it because I'm pretty tall.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
06-20-2012, 11:42 AM | #4 |
Hey guys, My truck is still a 3ott manual trans. My plans for later on are for a 5 speed but I still would like to move the steering column closer to the dash. The column shifter on my truck is in pretty good shape. I even have a hurst 3sp floor shifter,Im just not wanting to install it yet. The procedure from the FAQs show an auto column and collapsing the shaft.I just dont know if this will work on a 3ott.
Seems like it will put the linkage in a bind.Any ideas? Muley |
06-20-2012, 12:04 PM | #5 |
subscribe
1968 Chevy C/10 LWB V8 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
