Old 06-19-2012, 02:23 PM   #1
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Plug wires for Hooker headers and HEI
I just installed Hooker Long Tubes on my 69 and the straight plug boots are really close if not touching on a the headers.
I have searched and searched and the only thing I have found is tons of info about Ram Horns and 76+ corvette wires.....not sure if that applies here.
What are people with this combo using. I'm thinking I need a 90 degree boot and I would like the wires to be a good fit.
I was thinking about ordering these to clean it all up.
http://www.summitracing.com/parts/RNM-1101P/
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 06-19-2012, 03:39 PM   #2
dracula4999
dracula4999's Avatar
Re: Plug wires for Hooker headers and HEI
I used 90 degree boots on mine and ran the back two wires on each side under the header, and the front two along the intake and around the front of the engine. But mine were cut to length wires so they were plenty long enough.
71 GMC long bed
70 Chevy short step
71 Chevy K10 long bed
dracula4999 is offline   Reply With Quote
Old 06-19-2012, 11:56 PM   #3
I'll have to double check,but I believe it's '86 heavy GVW 3/4t plug wires you need. They came up over the tubular manifolds
Old 06-20-2012, 09:40 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
You can't use straight boot plug wires with headers. About 99% of the time.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-20-2012, 09:54 AM   #5
Willys47
Willys47's Avatar
I har to use 45 angled plug end on my leads worked great
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 06-20-2012, 12:06 PM   #6
Cole Trickle
C-10 Club Member
That would be great
Old 06-20-2012, 12:07 PM   #7
Cole Trickle
C-10 Club Member
Gary
I am making contact in a couple places so they need to be changed.
Old 06-20-2012, 08:57 PM   #8
hayhauler71
hayhauler71's Avatar
90 deg boots work best also a good set of wire looms and custom make your wires
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 06-20-2012, 11:42 PM   #9
rico7769
Hybrid67
rico7769's Avatar
Agree and I added accel shorty plugs. They are about $30 or so and come in a set of eight. Run about 1/4" shorter than std plugs.
Keep em' Running!
All show.....no go
rico7769 is offline   Reply With Quote
Old 06-21-2012, 12:40 AM   #10
PAWS 72
PAWS 72's Avatar
Let's see #6 plug and #1 wire.Thats where i'm having trouble.Please
PAWS 72 is offline   Reply With Quote
Old 06-23-2012, 02:35 PM   #11
Jack_71C10
Shortbed club member
Jack_71C10's Avatar
I used the '86 3/4 ton wires like Special-K mentioned.
But you have to check before purchacing some sets come with 2 straight boots, the rest are all 90 deg. boots.
They are also too short to run like the picture in Hayhaulers post, You have to run them over the valve covers.
71 custom/10 6.0/4L80E SWB ece 4/6
72 custom camper 350/3 spd
2020 Chevy Express 3500
2023 Hyundai Tuscon
1986 GMC 3500 Bucket Truck
Sent from my Rotary Phone via 14.4kb/s modem.
Jack_71C10 is offline   Reply With Quote
Old 06-23-2012, 02:46 PM   #12
shawno72
C/10 junkie
shawno72's Avatar
I personally like to run the wire looms, it looks clean and functions perfectly. Also they are only $29.99 shipped on eBay. http://www.ebay.com/itm/390401858116...84.m1438.l2648
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 06-23-2012, 11:03 PM   #13
hayhauler71
hope these help you out
Fuzzy
Old 06-23-2012, 11:33 PM   #14
PAWS 72
PAWS 72's Avatar
Thanks looks better than I thought. I'm running the cheap Hedman headers ,mine look like ;;;;.#6 has to be taken out with a wrench and #1 the plug wire is about 1/8 inch from the header.
Old 06-25-2012, 06:48 AM   #15
Those are one type of wire loom that are shown. There are many types of looms. I don't like that type because it puts the wires real close to the heat. I don't mind seeing plug wires and use ones that hold the wires up and away from the heat. And,as mentioned,the HEI wires I suggested won't work with that set-up anyway.
Old 06-25-2012, 08:05 AM   #16
bigsnookmaster
bigsnookmaster's Avatar
I run MSD cut to length wires and run them under the headers and around the back of the block. It's real clean looking. I have this thing about hiding wires of all kinds.
bigsnookmaster is offline   Reply With Quote
Old 07-06-2012, 01:35 PM   #17
Frijolito1988
I am having this same problem with my Hooker long tube headers, going to try and run them under the headers and up behind the block for a clean look.
Frijolito1988 is offline   Reply With Quote
Old 07-06-2012, 03:08 PM   #18
Cole Trickle
C-10 Club Member
I ended up purchasing the loops I posted and Accel 8.5 mm wires from the 1986 3/4 ton truck .
Everything worked good but 2 of the wires are a tad short at the back of the valve covers.
I also ended up with a new edelbrock fuel line and filter/feed combo.....That was a fun day
Old 07-06-2012, 03:24 PM   #19
shawno72
C/10 junkie
shawno72's Avatar
Looks good though.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 07-06-2012, 05:38 PM   #20
Frijolito1988
What did you do about the short wires ?
Old 07-06-2012, 07:04 PM   #21
Cole Trickle
C-10 Club Member
They worked there just touching the rear of the valve covers.
There won't be any issues but there not 100% perfect.
I might be able to swap them with one of the other wires but it was a big gamble to swap when it was already done and in the looms.
Old 07-06-2012, 07:32 PM   #22
Frijolito1988
Gotcha. I am gonna go ahead and go this route. I am going to try the 86 3/4 ton wires with out the bracket and see how it works out , if not them im gonna go ahead and buy that too. Thanks!
Old 07-06-2012, 07:39 PM   #23
Ok,it's more like '76. They are shorter and you run them using looms (real looms) up and over the valve covers away from the heat. I see you got '86 and they work. Sorry for the confusion. I actually need new wires and I'll see what I end up with asking for '76 HD C20
Real looms:
http://www.jegs.com/p/Moroso/Moroso-...48807/10002/-1
http://www.jegs.com/p/Trans-Dapt/Tra...24379/10002/-1
http://www.jegs.com/p/Proform/Profor...02311/10002/-1
They call these looms,but they aren't really. Plug wire routing devices???:
http://www.jegs.com/p/Billet-Special...44153/10002/-1
A loom is a device that holds strands apart. Think weaving,that's a loom. You don't want wires running at lengths side by side and you want them up and away from the exhaust manifolds/headers,away from the heat as much as possible. Those billet things get hot and heat the wires,not good.
Here are the premium stock (8mm) replacements from NAPA for '76 C20 w/350.:
http://www.napaonline.com/Catalog/Ca...244_0065537382
Old 07-24-2012, 01:16 PM   #24
Frijolito1988
Going to get the 76 C20 3/4 TON from Autozone , Duralast. hope these work. I already have " real " wire looms.
http://www.autozone.com/autozone/par...fier=2762_0_0_
