Old 06-19-2012, 04:32 PM   #1
dmoss69
fuel pump and tank for fuel injection
What's the cheapest tank or pump set-up that I can find for putting a in-tank fuel pump setup under my 85 shortbed?
What I have:
1985 chevy shortbed
It has dual tanks
I'm taking one tank out, if not both, and replacing them with a tank that I can put the high performance fuel pump in.
I have a high performance pump now, 340lph, so all i need is the sending unit piece to adapt, or if there is a cheaper tank alternative to try.
I didn't see anything as of yet, I'll go search some more!
D Moss
1985 GMC high seirra, 6.0 ls turbocharged
several others.....
dmoss69 is offline   Reply With Quote
Old 06-19-2012, 05:08 PM   #2
rs72z
rs72z's Avatar
Re: fuel pump and tank for fuel injection
You can get a rear mount tank for a 87-91 suburban and the sending unit also. The tank has the baffles built in it.
There's sevral threads on here on how to make the mounts.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 06-19-2012, 08:26 PM   #3
hatzie
Moderator
hatzie's Avatar
You can use 87-91 R/V TBI senders in your existing tanks. With a fuel pump matched to your fuel injection setup. The only downside is your tanks don't have baffles.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-19-2012, 11:12 PM   #4
rs72z
rs72z's Avatar
If you want to stay with the side tanks get them for the 87-91 truck, they have the baffles also.
___________________
78 ccsb dually
5.3
4l60e
Old 10-22-2012, 11:51 PM   #5
dmoss69
rs72z....
So a fuel tank out of a shortbed 88-91 pick-up will work? Bolt in?
If so, I should be able to get one of these really easy, and put my pump on the factory bucket set-up.
D Moss
several others.....
Old 10-23-2012, 06:35 AM   #6
D13
D13's Avatar
88 up short bed tanks will not work!
You need 87 short bed tanks (which have the baffles), or you can use the sending units from one of the TBI squares, any 1987 all or 1988-91 crew cabs, mounted into your existing tank. you won't have the baffles so don't plan on racing with low fuel.
Probably the best set up is to convert to a rear mounted 87-91 K5 Blazer tank, moves the weight back and pretty easy to do, judging by some of the threads on the board (do a search here, lots of good info).
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 10-23-2012, 07:35 AM   #7
rs72z
rs72z's Avatar
What he said
___________________
78 ccsb dually
5.3
4l60e
Old 10-23-2012, 05:39 PM   #8
hatzie
Moderator
hatzie's Avatar
I don't think they made shortbed RV trucks after 1987.
Old 10-23-2012, 05:43 PM   #9
earnhardtgm3
earnhardtgm3's Avatar
Smile Re: fuel pump and tank for fuel injection
Why not use a external inline fuel pump from Bosch or Walbro brand.I'm using the Bosch with a MSD atomic EFI kit.
1977 Chevrolet Scottsdale:
1979 Camaro Z2/8
http://www.nastyz28.com/forum/showthread.php?t=129623
earnhardtgm3 is offline   Reply With Quote
Old 10-23-2012, 05:48 PM   #10
AJII
AJII's Avatar
No need to reinvent the wheel. Just get tanks and sending units for an 87 SWB. Done
1985 K10 Under Severe Reconstructive Surgery
5.3/New Paint/New Interior/Yadda Yadda Yadda
AJII is offline   Reply With Quote
Old 10-23-2012, 06:00 PM   #11
rs72z
rs72z's Avatar
Everyone has their own opion on fuel pump location. I would never use a external pump if i could use a intank pump. The reason being is the intank pump is cooled by the fuel in the tank. The second reason is if you are away from home and have a pump go bad any parts store should have a pump to get you going.
I had a external pump on a truck with f.i. once and everytime it got summer in TX it would leave me on the side of the road. jmo
___________________
78 ccsb dually
5.3
4l60e
Old 10-23-2012, 06:44 PM   #12
MalibuSSwagon
I just went the easy route and ordered a 87 R/V TBI tank and sending unit. Was fairly inexpensive as well.
MalibuSSwagon is offline   Reply With Quote
