Old 06-19-2012, 06:10 PM   #1
csa daddy
csa daddy's Avatar
my new to me 1986 chevy sub
i just picked up a 1986 chevy suburban with a 6.2 diesel in it with 182,000 miles on it. im the fourth owner the woman i got it from said her grandfather bought it new in 86 an ordered the heavy duty tow package on it with a posi track rear. pretty clean if i have to say so myself.
an here is a pic of it after i put my cowl hood onit curtousy of top bananna parts fit great by the way
csa daddy is offline   Reply With Quote
Old 06-19-2012, 06:49 PM   #2
SBTork
Garage wrench
SBTork's Avatar
Re: my new to me 1986 chevy sub
Nice rig! What are the plans for it?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 06-19-2012, 07:20 PM   #3
csa daddy
csa daddy's Avatar
Drop spindles an bags a small 4 inch notch in rear an flip axel over top of springs an bag the rear like justpball done his. Also plan to get a set of 18x8 streeter wheels for the front an a set of 20x10s for the rear
Old 06-22-2012, 01:45 PM   #4
kikkegek
kikkegek's Avatar
gonna follow your build...nice Burb
kikkegek is offline   Reply With Quote
Old 06-22-2012, 04:59 PM   #5
68Timber
I know the pieces fit
68Timber's Avatar
Love the 2wd diesel Burb's. Looking forward to seeing it lowered.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-07-2012, 02:23 PM   #6
csa daddy
csa daddy's Avatar
Ok update Im planning to pick up a set of 18x9 boss 304 wheels next weekend. So that will be another step closer also i have put my 12" subs in an a 1500watt amp an lighting cap
Old 07-07-2012, 02:34 PM   #7
csa daddy
csa daddy's Avatar
thanks everyone whos following here is a update pic for 3" spindles in a little rubbing on the rallies at full lock an had to move brake lines to clear the spindles
Old 07-07-2012, 02:42 PM   #8
csa daddy
csa daddy's Avatar
pic of where i want it to sit when done thanks to justpball
an here is a pic of the wheels im getting
Old 07-07-2012, 02:45 PM   #9
csa daddy
csa daddy's Avatar
First car show today for the burb will try to pus pics this evening if anyone is interested
Old 07-07-2012, 04:20 PM   #10
kikkegek
kikkegek's Avatar
yeah yeah yeah...
Old 07-07-2012, 04:28 PM   #11
csa daddy
csa daddy's Avatar
K it's just a small show so dont get to excited
Old 07-07-2012, 06:02 PM   #12
kwin
kwin's Avatar
What size are those wheels?
kwin is offline   Reply With Quote
Old 07-07-2012, 06:05 PM   #13
csa daddy
csa daddy's Avatar
18" need to find a couple 20x10s for the back
Old 07-07-2012, 10:15 PM   #14
csa daddy
csa daddy's Avatar
car show pics
Old 07-07-2012, 10:24 PM   #15
csa daddy
csa daddy's Avatar
I Will put up some more tomorrow home computer acting stupid an froze up so No more pics tonite
Old 07-08-2012, 03:38 AM   #16
kikkegek
kikkegek's Avatar
nice!
Old 07-08-2012, 10:39 PM   #17
68Timber
68Timber's Avatar
The wheels look great, nice choice. Any turbo plans?
John
74 Honda Z50 build
Old 07-09-2012, 12:33 AM   #18
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Cool looking burb looks super clean. Sounds like a fun project cant wait to see it when its done Some sweet looking rides at the car show as well.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 07-09-2012, 07:17 AM   #19
csa daddy
csa daddy's Avatar
If I turbo it I will proably just swap a 6.5 in it but that will only come after the 6.2 dies. I dOnt need to fly up the highway so the 6.2 does all I need it to plus it gets great fuel mileage. So why mess with it.
Old 07-09-2012, 12:35 PM   #20
Edahall
There are also some low costs things you can do to help that 6.2 as well.
1. Biggest bang for the buck will be a free flow exhaust. The stock setup is very restrictive. A super single 3" works well. Or if you want a mean sounding setup, go with dual 2.5" / H-pipe and some old fashioned Thrush / Walker glasspack mufflers.
2. J code air handler (intake manifold). This air handler has no EGR. Or if you want to save some money, you can simply chip out the EGR pedestal.
3. BHAF (Big Honkin Air Filter). Basically, stack 2 air filters on top of each other.
Of course to take advantage of all of this, you'll need to turn up the injection pump.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 07-09-2012, 01:01 PM   #21
csa daddy
csa daddy's Avatar
Exhaust plans are to build one of the exhaust adapters by a dr lee swagger from over on the diesel forum an run 3" from 2.5 adapters back with proably flowmasters not sure if it's a j code or c code motor had t checked yet. I got a 6" k&n filter I could put on but would have would have to make a top for the filter. I do plan to install some hot glow plugs eventually
Old 07-09-2012, 03:12 PM   #22
Edahall
If you've read up on Dr. Lee Swagger, you've got the right idea.
1/2 ton Suburbans would have come stock with a C code motor.
K&N's are OK as long as you don't drive down dusty roads. They don't tend to filter out the dust as well as a paper element filter.
Bypass that glow plug controller with a push button before it causes you grief. But make sure you select the right glow plugs that can handle extended glow plug times. I'm using AC Delco 60G but there might be something preferable right now.
Old 07-09-2012, 05:27 PM   #23
csa daddy
csa daddy's Avatar
I forget which ones exactly but I think they are Keith something an my old motor which was a 1/2 ton 4x4 an had a j code motor an the one my dad had which is now in my 91 sub is also a j code motor an like I said just had t checked the numbers to see about this motor. Never real had problems with factory controller but how would you do that
Old 07-09-2012, 05:36 PM   #24
Edahall
I wired up an automotive 30 amp solenoid to engage the glow plug solenoid. My push button engages the 30 amp solenoid which then engages the glow plug solenoid. The glow plug solenoid is bolted to the inner side of the drivers side fender.
If you do this, you want glow plugs that won't burn up with extended time.
Glow plug controllers are expensive and when they do go out, you're pretty much stuck.
Old 07-09-2012, 05:43 PM   #25
csa daddy
csa daddy's Avatar
Right I will have to check into it am maybe get a spare to carry with me. So far I have replaced several of the fuel return lines on the motor an the brake line an caliper Was wondering about turning up the injector pump but have never messed with one so
