Old 05-16-2003, 02:01 PM   #1
lock
Insert funny comment.
lock's Avatar
Rear end swap question
I recently pulled a 10 bolt rear end from my 86 IROC... it has 3.73 and Auburn Pro posi in it. Id really like to swap this into my 68 C10 so that I get the 3.73's and 5 lug. Will this rear end swap in? Anything special I need to do.. Im wondering how the truck arms will mount. My 68 is a coil spring setup.
Thanks!
- Mark
-My Build Thread...
-68 C10, LT1 - Undergoing Frame off resto
-86 IROC-Z T72 turbo 355, M6
-70 Camaro
http://www.iroc-ss.com
lock is offline   Reply With Quote
Old 05-16-2003, 03:05 PM   #2
Roberty
Hot Damn - Here I Am!!
Roberty's Avatar
How does it compare in width to the one in your truck? As far as the brakets go I saw a link on the board here for the weld on brakets to be able to convert a different rearend to fit in our trucks. I didn't save the web address though.
Robert
My vehicles:
'90 Silverado Sport
'71 Chevelle SS Convertible
'70 C-10 - My Grandfather bought it new - original un-restored
Roberty is offline   Reply With Quote
Old 05-16-2003, 03:38 PM   #3
tom hand
CCRider
tom hand's Avatar
Chevyduty and others sell kits to install non-coil spring rearends in our trucks. Is it wide enough? The rear end is a five bolt pattern but it is 5 on 4 3/4 and our trucks are 5 on 5 so you would need to have your front rotors redrilled to have the same pattern all the way around. Good luck
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 05-16-2003, 08:07 PM   #4
lock
lock's Avatar
Ive converted the front to disc brakes with a setup from a 75 truck.
- Mark
-My Build Thread...
-70 Camaro
Old 05-16-2003, 09:03 PM   #5
70c10
67-72 Addict!
70c10's Avatar
lock, how much of that front end did you use?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-16-2003, 10:28 PM   #6
Blue Beard
Blue Beard's Avatar
Is the bolt pattern the same on the car?
Thought they were different that the trucks...........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 05-16-2003, 11:16 PM   #7
69c10Lwb
86 iroc rear end
the bolt pattern is a 4 3/4 vs a 5.0 , but it is also a 7.5 ring gear most likely unless you stepped up to a aftermarket rear axle. what im trying to say is that you are going to a weaker rear axle . true the auburn posi is a good posi,but youre still using a small axle and it has the 4 3/4 bolt pattern. so it really comes down to how much are you willing to modify to make it work. plus the truck is heavier than the camaro it came from and that will affect the life span if you run the truck hard especially.....hope this helps and good luck.
1973 pro-street nova back halved 632 cid 9inchford, disc brakes,2stges of spray,t-400 w/brake . almost done.
1952 chevy pick up soon to have a 468 bbc (hopefully momma will be happy with it and let me play with my toys more)
nds.1983 ford bronco 400m auto matic 4wheel drive (war wagon, seen many battles and lost most )
another 1969 lwb project.
suspension ??
motor ?? driveline ?? when you get it for free you dont turn it down... right???? 1992 suburban 4x4 no mods yet
69c10Lwb is offline   Reply With Quote
Old 05-17-2003, 12:00 AM   #8
lock
lock's Avatar
I used spindles and everything mounted form the truck on the front end. The iroc is 320hp, 410 torque at rear wheels. Yes the 10 bolt is suspect but this one has proven strong for me so far. My truck isnt as strong as the car. Im not concerned about tearing up the 10 bolt, rather jsut if I can get it in.
Ill check the bolt pattern this weekend and see.
Thanks for all the replies everyone!
- Mark
-My Build Thread...
-70 Camaro
Old 05-17-2003, 08:48 AM   #9
onetoncrewcab
One of my kids. Cute eh?
onetoncrewcab's Avatar
Here is a link to the thread I had started a couple of weeks ago. This might be the one Roberty is thinking of too.
http://64.246.42.114/vboard/showthre...threadid=52681
I have an 86 Sub that I'm pulling the rear axle out of. I knew there was new brackets available and someone on here knew about them too. But one member said I can just switch the axle shafts. I'm not sure of that yet. I think the Sub axle is longer.
I HAVE to get my wife's kitchen done before I can go work on the truck. Then I hope to get some progress pics on it.
Later
Mike
If a kid asks where rain comes from, I think a cute thing to tell him is “God is crying.” And if he asks why God is crying, another cute thing to tell him is “Probably because of something you did.
John 3:16
2006 Chevy HHR
2000 Dodge Durango
1985 Jeep CJ-7
1970 Chevy Pickup
onetoncrewcab is offline   Reply With Quote
