Old 06-19-2012, 11:50 PM   #1
school boy
school boy's Avatar
Arrow converting to power windows
aftering searching the used market ive decided to spend a little more and buy new. can anyone suggest a good company they used? any help welcomed!
school boy is offline   Reply With Quote
Old 06-20-2012, 09:32 AM   #2
1774btcrew
1774btcrew's Avatar
Re: converting to power windows
If it was me I would stick with the factory GM stuff. It is tried and proven and when it finally wears out replacement parts are easy to come by. The install is straight forward and much easier than afermarket stuff. I have helped friends install aftermarket kits. They were a hassle to put in and just never seemed to work as well as the OEM stuff. Plus when stuff does break on them you have to order the parts and hope that company is still in business or the parts aren't obsolete. Aftermarket is fine if you can't find factory parts or it is a model vehicle the company that manufactured it never put PW in. When it comes down to it you just can't beat GM parts
1774btcrew is offline   Reply With Quote
Old 06-20-2012, 11:00 AM   #3
school boy
school boy's Avatar
could i use lmc? i know they have a lot of replacement parts
Old 06-20-2012, 06:39 PM   #4
1774btcrew
1774btcrew's Avatar
LMC is decent. I would suggest getting as much factory GM parts as possible though. You would definitely need a factory harness and relay. Pretty easy to come by. They I guess you could buy aftermarket regulators and motors from LMC if you wanted. At least that way it is easy to find replacement parts as needed.
Old 06-20-2012, 10:48 PM   #5
school boy
school boy's Avatar
thanks for your help!
Old 06-24-2012, 01:47 PM   #6
va944
Check out a company called new relic http://www.nu-relics.com/
I used these in a 47 build project and they are awesome. They are designed specific for your vehicle and are not universal. Their system bolts in place of stock regulator.
va944 is offline   Reply With Quote
