Old 06-20-2012, 08:09 AM   #1
Pife
Wood floor Blazer
Is a Blazer rear bed the same length and width as a SWB truck? Has anyone seen a wood bed done on a Blazer? Any posts or pictures would be great. I have been searching to avail. Thanks!
Pife is offline   Reply With Quote
Old 06-20-2012, 11:46 AM   #2
Bshift426
Bshift426's Avatar
Re: Wood floor Blazer
I believe that they are the same width, but the length is about 6 inches shorter for the Blazers. The only reason I know that is because I am looking to swap out my rusted and beat up bedsides with ones from a SWB and have been told that I will have to cut 6 inches off of it to make it work. I would be really interested to see how a wood bed looks in a Blazer. That could look really good.
72 Chevy Blazer
Bshift426 is offline   Reply With Quote
Old 06-20-2012, 04:34 PM   #3
Boneyard
jaros44sr has one. Check out this thread http://67-72chevytrucks.com/vboard/s...d.php?t=210641
Boneyard is offline   Reply With Quote
Old 06-20-2012, 07:24 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I'd be worried about mounting a backseat to a wood floor. In the event of an accident, I wouldn't think the wood strips would be solid enough to keep the back seat inside the truck.
If you don't plan on running a back seat, it could be nice looking. Is there enough support to mount the body to the frame and handle the flex a blazer gets?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 06-20-2012, 08:52 PM   #5
jaros44sr
jaros44sr's Avatar
Extremely valid point on mounting the rear seat, although all factory lateral braces were retained, i had no intention of putting a seat back there. Also, all factory body mounting brackets were used. Dont know about flexing...to be determined
If, and that is a big IF, the seat were mounted to the floor, it would have to rip out the lateral supports under the wheel wells, the wheel wells, inner and out bedsides. That is quite a bit of metal to move, BUT, is it worth the chance that something might fail...
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-20-2012, 08:53 PM   #6
Bentblazer
Bentblazer's Avatar
Jaros44sr would be the one to help the most since he's done it, but just off the top of my head I believe you have to have pickup cross rails which allow for the thickness of the wood? Then the area where the bed mounts to frame? I think that the metal backing plate under the bed floor will help with the back seat as it covers such a wide area across bed. Does look cool!
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 06-20-2012, 09:01 PM   #7
BOHICA
BOHICA's Avatar
If it were me, I'd just do a false wood floor and not deal with the headache of cutting out my old one.
1954 Ford F-100
1956 Chevy big window
1970 4x4 Blazer CST
1987 Land Cruiser
1990 Chevy K3500 454
BOHICA is offline   Reply With Quote
Old 06-20-2012, 09:35 PM   #8
Pife
jaros44sr What kit did you get? What page on your build do you detail the install of your floor? I am looking at a Blazer without a bed floor. I am thinking that the wood would be really cool and easier than replacing with metal. If I were to install a rear seat I would put in extra bracing under the floor and use some larger grade eight hardware. Thanks for the input guys.
Old 06-20-2012, 10:28 PM   #9
jaros44sr
jaros44sr's Avatar
Not a kit, just bought the matrl. for a 6 ft bed, and cut an extra 6" off of it. Mar-k sells the stuff.
Ill have to go look and see what page it starts
SAFETY FIRST
AS usual, off topic
Jim
Old 06-20-2012, 11:19 PM   #10
72gmcshorty
72gmcshorty's Avatar
you could do a nice laminate flooring...
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 06-21-2012, 03:36 PM   #11
jaros44sr
jaros44sr's Avatar
I strongly dont recommend the mounting of the rear seat.....
Your in uncharted waters with how strong the wood is, later on, with rot and deteriation
and who knows what. Just not a good idea, but that is just my humble opinion
Ill answer any questions you have on mounting the wood to the bed, as best of my knowledge
SAFETY FIRST
AS usual, off topic
Jim
Old 06-21-2012, 06:34 PM   #12
Bentblazer
Bentblazer's Avatar
Why do a good looking floor and cover it up with a seat anyway?
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Old 06-21-2012, 07:33 PM   #13
jaros44sr
jaros44sr's Avatar
And yet, another good point to consider
SAFETY FIRST
AS usual, off topic
Jim
Old 06-21-2012, 09:28 PM   #14
Ole Beater
Hey guys. Usually its where the seat bealts anchor and not the seats that protect you in an accident. Either way i think that wood floor looks nice.
Ole Beater is offline   Reply With Quote
Old 06-21-2012, 10:18 PM   #15
jaros44sr
jaros44sr's Avatar
SAFETY FIRST
AS usual, off topic
Jim
Old 06-22-2012, 09:03 AM   #16
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Wow.
Tom Vogel is offline   Reply With Quote
Old 06-22-2012, 03:02 PM   #17
CTENTA1
Registered 1971 K5
Cool to see someone has done this. I thought about doing it also at one point.
http://67-72chevytrucks.com/vboard/s...d.php?t=332449
Post #26
CTENTA1 is offline   Reply With Quote
Old 06-22-2012, 03:08 PM   #18
jaros44sr
jaros44sr's Avatar
Post #26
Thanks...maybe i should stick over there, never saw that thread before
Wonder if the pick up truck guys would mind...
SAFETY FIRST
AS usual, off topic
Jim
Old 06-22-2012, 03:28 PM   #19
CTENTA1
Registered 1971 K5
Nah...your good here! Never did I get replies, so im thinking they thought I was crazy!
I can tell you dont think Im crazy, Lol...
Old 06-22-2012, 04:11 PM   #20
Bentblazer
Bentblazer's Avatar
We got your back Jim
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Old 06-22-2012, 06:02 PM   #21
jaros44sr
jaros44sr's Avatar
Thanks for the offer, but they out number us like ten to one...lol
SAFETY FIRST
AS usual, off topic
Jim
Old 06-22-2012, 08:15 PM   #22
Pife
It looks great!. I don't even own a Blazer yet. I am looking at one with out a bed floor in it. It is about 14 hours away and don't know how to economically get it home. I was kicking around the idea of pre cutting some plywood and loading up some tools and renting a car? My wife thinks I'm nuts.
Old 06-22-2012, 08:54 PM   #23
jaros44sr
jaros44sr's Avatar
U-HAUL, seems like the least costly...dont worry, wife thinks im nuts too
Road trips are fun
SAFETY FIRST
AS usual, off topic
Jim
Old 06-22-2012, 09:10 PM   #24
jaros44sr
jaros44sr's Avatar
Post #26
I answered your question ctenta after 3 years....
Get ready buddy, i think theira comin fer us
SAFETY FIRST
AS usual, off topic
Jim
Old 06-22-2012, 10:56 PM   #25
Pife
jaros, Will a Blazer fit in a U haul?
