Old 06-20-2012, 12:08 PM   #1
YahamaR1
YahamaR1's Avatar
Question 454 big block in 51 chevy truck
Hello everybody..
I have a question about my build,
I am almost finisht with the build of
My 454 bigblock
What kind of alternator en poliesystem are you
Using, and what kind of waterpump are you using?
A long one ore short pump..?
The block have too go in a 1951 chevy AD truck...
I am from the Netherlands. And now I am looking
For a nice chrome beltsystem.
Can someone help me..?
YahamaR1 is offline   Reply With Quote
Old 06-20-2012, 01:15 PM   #2
Speedbumpauto
Speedbumpauto's Avatar
Re: Question 454 big block in 51 chevy truck
My BBC is in a 55 with a clip but engine wise it should be the same. Mine is a MK-4 which is the older big block. I used a March pulley set for a stock 454 with power steering and used the stock GM brackets. I made the AC bracket out of strap and tubing and put it down low since I hate the aftermarket ones that put things way up in the air in front of the engine. The idler pulley is an auto parts store purchase and is bolted to the alternator bracket. I measured it all with a seamstress tape and bought a belt to fit. I powder coated my brackets with what we call 5 foot chrome, but you could have your parts plated, depending on the look you want. The only caveat is with the AC lower, you can't run a mechanical fuel pump which wasn't in my plans anyway. Here are a couple of pictures.
Speedbumpauto is offline   Reply With Quote
Old 06-22-2012, 05:51 PM   #3
wildearp
wildearp's Avatar
Look at Bills Bracket Company. Speedway Motors sells them too.
wildearp is offline   Reply With Quote
Old 06-23-2012, 07:58 PM   #4
wayne4252004
wayne4252004's Avatar
I have a 51 GMC as well but mine is ontop of a 75 3/4 ton 4x4 frame. I'd like to put a big block in it. Is there any mods that you had to do to fit your big block in your truck. Such as cab placement, fenders, radiator, etc? Mine currently has a 350, but it looks like a very tight fit.
Thanks,
Wayne
wayne4252004 is offline   Reply With Quote
Old 06-24-2012, 02:57 AM   #5
YahamaR1
YahamaR1's Avatar
Thanks,
Wayne
Mine is on the original chassis, with a Heidts ifs..
The only thing is my firewall, i have to make some changes.
And my Headers are really tight.. But it is fitting, the cab is on his
Original place..
I have a long way to go,, but is really nice when everything is finisht..
7.4 L in a 51" ..... I like it.!!!!!
Old 06-24-2012, 09:57 PM   #6
pgf545
pgf545's Avatar
Look at my build thread and I have several pictures. I am doing a 454 in a 52 but everything should be the same as your 51. It is really tight but so far everything is fitting...lol.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
