06-20-2012, 02:18 PM | #1 | |
FarmBoy.
Shock question about drop (truck parts not on a truck)
Ok guys. As some of you knOw I cobbled a trailing arm set up underneath my 67 chevy II.
I'm using Buick Roadmaster coil springs, and righ now have stock truck shock mocked up. I'm wondering if I should just shoot for Buick shocks, stock truck shocks, or get a set of like 3 in drop shocks... This is all kinda new to me, so, oh suspension guru's....what would you do? Thanks in advance! Posted via Mobile Device
1969 GMC C1500. long fleet. 307. 3 on the tree. 3.07 gears. Oliver green. Bent and bruised. Daily Driver. Quote:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993 |
06-20-2012, 02:42 PM | #2 |
It's Better With Nitro
Re: Shock question about drop (truck parts not on a truck)
I would mock up everything at ride height and measure the shock length. From there, you can look up the type/brand of shock you want to run by travel length (compressed and extended length), choosing the appropriate shock part number by the mid-travel length.
06-20-2012, 09:20 PM | #3 |
A guy with a truck
To add to that, I would look for something from a similar weighted vehicle, to get the proper valving. You wouldn't necessarily want a shock made for a Honda Civic, or a 1 ton dually under your Nova...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
