06-20-2012, 04:57 PM | #1 |
'68 C20 No bite 2 Brakes!
Hello Again.
I just completely redid my front drum brakes (cylinders/shoes/drums/clean), and installed a new Master. Brakes have a large booster, about 5" deep. Bled, bled, bled all four wheels until clean fluid came out, and brake was/is firm. No leaks. On my test run, there was little to no bite to my brakes. It was more a slow drag, w/ my applying strong leg pressure. The pedal remained firm 3/5ths the way down. Maybe Booster? Not certain how to test? That little manifold thangy below the Master? How test that ? I imagne I should have more brakes/SOME brakes even if the rears are poor as it is a dual reservoir? Thanks, and I apologize ahead of time if this topic is over grilled! |
06-20-2012, 05:06 PM | #2 |
Re: '68 C20 No bite 2 Brakes!
First off I'd suggest a factory service manual for '68. off the top of my head excessive shoe clearance fron or rear might be your problem. The proportioning valve requires a clip or a tool to hold it while bleeding, might also be an issue. Did you pressure bleed the system and bench bleed the M/C?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
06-20-2012, 05:39 PM | #3 |
I bench bled the master so fluid came out both reservoirs. I even bled in the truck a couple squirts.
Not certain what pressure bleeding is, but I bled each wheel w/ the nipple over bleeder to hose in cup w/ fluid technique. I do have a couple manuals, and those have been an aide. I hand adjusted the front shoes til a slight scrape. I never in my 43 years bled a proportion valve? What is the name of said tool? The booster is actually more like 7" thick. |
