Old 06-20-2012, 07:17 PM   #1
gmech
C-30 Front Air Bag Brackets... Help Me
Ok, so I am putting Slam Specialties SS-8 on the front of my Crew Cab. I have looked online at some cross member and control arm mounts. I decided to have my own made, made a template and had my freind cut it out on his plasma cutter. I did this knowing that I would have to put a bent in it to follow the contour of the crossmember/ control arm.
My problem is that they look pretty bulky when I put them up to the cm/cr's. Im am only using air bags for the ride and no tricks. Have any of you done this to your rides and how did you do it.
gmech is offline   Reply With Quote
Old 06-20-2012, 08:44 PM   #2
rs72z
rs72z's Avatar
Re: C-30 Front Air Bag Brackets... Help Me
I can't help but will be following along. I want to put bags on the front of mine for the ride also. I was thinking of using some 2600 bags and just use bolt in cups on the bottom. But i don't know if it will work or not.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 06-20-2012, 09:04 PM   #3
gmech
rs72z
I am thinking of cutting round plates to weld flush into the pockets of the control arms. Might even have the whole pocket cut out. For yours, Ive seen where guys cut out the spring pocket an weld in a "cup" that is big enough to house the bag. If I find the pick I'll post it. Yours will sit lower the control arm than mine because of the ride height. THe crossmember is a different story, I need to be able tighten the bolts on my airbags. Like i said the plates I had cutout would work but I just dont like the look. I wish I wasnt so damn picky!
Old 06-20-2012, 09:09 PM   #4
gmech
One other thing is that you will need to remove the bump stop mounts. I went with the SS-8's because theyre not suppose to increase in diameter as pressure increases and they have bumpstops built in. Ive heard that most bags increase in dia on pressure increase.
Old 06-21-2012, 05:44 PM   #5
gmech
Well I took my control arms in today to get the spring pockets cut out and have a flat peice of 1/4" welded in. Should have them tomorrow. I just wish I would have thought if this earlier being that there already powdercoated. I am going to use the crossmember plates that I had made. You dont notice them as much I guess.
Old 06-21-2012, 06:35 PM   #6
rs72z
rs72z's Avatar
pics when done please.
___________________
78 ccsb dually
5.3
4l60e
Old 06-21-2012, 07:10 PM   #7
gmech
I'll post them as soon as I get them home.
Old 06-21-2012, 07:26 PM   #8
cochino12
It followed me home?
cochino12's Avatar
Did you sink the plate down in the arm at all? Was there enough room to keep the sway bar mounts? I ended up getting rid of mine, still turns great without it.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 06-21-2012, 07:34 PM   #9
gmech
I am having them mounted flush. I still want the stock ride height. I am hoping to still use the sway bar.
Old 06-24-2012, 09:58 PM   #10
gmech
Was able to get the crossmember brackets bent as needed, and they also finished my lower controls arms. Unfortunatly, I was only able to get things mocked up so I can get things marked to drill holes etc. Saturday I had to run a A/C service call and then mow our churches grass. And today church, family and mow my own grass. Anyhow here is a couple pics to see how things look.
Old 06-24-2012, 10:09 PM   #11
gmech
Name:  crew cab airbag 003.jpg
Old 06-24-2012, 10:12 PM   #12
gmech
Name:  crew cab airbag 005.jpg
Old 06-24-2012, 10:16 PM   #13
gmech
Name:  crew cab airbag 006.jpg
Old 06-24-2012, 10:20 PM   #14
gmech
Name:  crew cab airbag 002.jpg
Old 06-24-2012, 10:22 PM   #15
rs72z
rs72z's Avatar
Looks good. Post some pics when it's all togther and aired out.
___________________
78 ccsb dually
5.3
4l60e
Old 06-24-2012, 10:26 PM   #16
gmech
That sure was painfull, It only took me about 20 minutes to download those pics. First i tried downloading all 4 at the same time, but I had to re-log in and start over. I love living in the country but this B.S. satilite internet sucks. Kinda takes all the fun out it.
Old 06-24-2012, 10:30 PM   #17
gmech
It will be awhile before I get to that point, this build is taking me alot longer than expected.
