2WD Jimmy
![]() Join Date: Mar 2005
Did these trucks have dual horns?
Ive got a 72 2wd Jimmy with a Cheyanne package. When I took it apart to restore, it had the 2 horns you see in the picture. I sent them off to restore, and the guy at the horn restore place seemed to think it was unusual for the truck to have dual horns. Well, I got them back and began to think, maybe someone just stuck an extra horn on here.
Whats the story/opinion of the experts on here. The picture you see is how the horns that were there were positioned. Is that right or no. ?? |
Re: Did these trucks have dual horns?
I'm certainly no expert, my 72 custom has dual horns. Wiring harness looks stock, I have no reason to think it was hacked in.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
They came with 2 horns - I believe it was for more volume, and to get the proper pitch.
Posted via Mobile Device |
Member
Definitely was an option, look at the wire going to the second horn. The wire should be green and plug into the harness right at the first horn. That wire/harness would be hard to make if the horn was added. In the pic the original second horn connector wire is original and a dull green, the bright green wire is part of a new harness i put in.
1970 CST LB Fleetside, 402 BB, PS, PB,AC 1968 Firebird 400 conv. 1965 Chris Craft 17' wood ski boat (SN #0001) |
![]() Join Date: May 2007
I have found dual horns on cst/cheyenne models, but not on the plain trucks.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
I found 2 horns in my 70 C20, I thought someone may have just put in a replacement & didn't take out the old one.
Moderator
Dual horns, one hi, one low
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Florida Edition
![]() ![]() Join Date: Oct 2010
U08 Dual Horn
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Maybe mine was just a replacement.
![]() Join Date: May 2010
Here's what the literature says (for whatever that's worth):
1969 and before- Not available. In fact, my early 69 CST/20 does not even have the provision (hole and weld-nut below left headlight) on the core support for the high note horn. 1970- Not available per the literature. However, I believe dual horns may have become available as an option during the model run. 1971- Included as part of Custom Deluxe, Cheyenne & Cheyenne Super option packages. No indication of availability as a stand alone option. 1972- Literature does not mention even as part of the higher level trim packages nor standard equipment. I THINK dual horns were standard on all the 1972 trucks. The literature I referenced is at www.gmheritagecenter.com Last edited by FirstOwner69; 06-21-2012 at 01:02 PM. |
#11 | |
![]() Join Date: Jul 2010
Board Member #87725 My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=813848 |
Your SPID and RenoKeene's would seem to indicate that dual horns were available as a stand alone option starting sometime during the 1970 model production. Interesting, however, is that RenoKeene's SPID (GMC?) indicates his is a 1970 CST and the dual horn is a separate option, and OSM 70 C20's SPID (Chevy)does not list the horns, but does have the Custom Comfort and Convenience Equipment that would have included the dual horns in 1971.
Just another great GM mystery!!! |
#13 |
The guys are right. The dual horns were an option even for the 1970's. My son's '70 GMC lists the U08 Dual Horn option on the SPID. The wiring is all original and comes directly from the harness.
If I remember correctly (I was 21 in 1970) this was another government safety mandate that was phased in during the early 70's. I believe it was part of the side safety marker lights and precursor to the 15 mph bumpers in 1973. NoNeck
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
#14 | |
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
#15 |
2WD Jimmy
Thanks Guys, I guess they are legit. hmm lol
#16 |
Crazy, never thought my 1st posts would be on a subject like this
#17 | |
In 1967, the Department of Highway Safety MANDATED that all vehicles manufactured or imported to the US be required to have the following safety features by the end of 1977; High-Decibel Warning Horns (could be either dual horns or High-Decibel single) Amber, Yellow or Red Side Marker Reflectors 15 MPH Crash Resistant Bumpers, Front and Rear 3 point Seat Belts (across the shoulder) Catalytic Convertor Emissions Control ...and probably a few more. Those are the ones I remember. Again, these MANDATES were phased in over 10 years. They began as options on the build sheets, but by 1977 they were required. Remember those ugly bumpers on the '75 Monte Carlos and Cutlass? NoNeck
#18 |
2WD Jimmy
Wouldnt it be great if Congress mandated no more mandates?
#19 | |
Side Markers was manditory in 1968 (seat belts were required the same year before that they optional) neither of these were a ten year phase in. Steering wheel interlocking ignition switchs (steering column keyed) was phased in over 2 years for 1969 and 1970 in cars. They were not 15 MPH but 5 MPH bumpers that were required on the front in 1973 and for the rear in 1975. The current requirement is for 2 1/2 MPH. Catalytic Converter were never required on any car (still are not today). It has to do with how the vehicles were Emission Certified, if it had cats to meet certification then they have to be on the vehicle. Remember the Subaru ads in the late 1970's and early 80's saying their cars did not require cats, and trucks did not get them on some models until 1986.
#20 |
I give up...
NoNeck
#21 |
Moderator
#22 |
My 72 has dual (high-low) horns. And just so you know Virginia REQUIRED my 84 Bronco to have a catalytic convertor. It didn't have to pass any emissions but had to have the convertor. Added a Cat(hollowed out) from a mid 90's chevy pu and got my inspection passed.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
#23 |
I pulled a set of dual horns off a 70 C20 government ordered pickup. The high note will not work ? Any suggestions on repair ?
71 C-20 07 Magnum RT AWD |
#24 |
Are you hoping to repair it yourself or have someone do it? I've taken quite a few horns out of junker trucks. The lows are usually good, but the highs are usually inoperable. I think the highs get more water in them due to the mounting position.
The horns are really quite simple, but I've had only fair results doing it myself. When I was restoring my '58 Vette, I had the horns professionally restored. That was in the late '80s, and I don't think he's around anymore. One of the current NCRS magazines has an ad for "The Horn Works" (www.CarHornRestoration.com). The ad says "restoration specialist of collector car horns". Of course these are probably NCRS level restorations. According to the website there is a limited time June special of $195/pair (normally $239/pair). I have no personal experience with him. |
#25 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I like the sound of Cadillac dual horns from the 70's to early 80's. I have them in my Elkie and K20. Very loud and sound manly. ..lol
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
