Old 06-21-2012, 10:59 AM   #1
AJohn6
Knuckle head
AJohn6's Avatar
A 9" rearend question for the "Mad Scientists"
I ordered the Currie 9+ Centurion Ford 9" reared end housing, 3" DOM tubes, late model big Ford billet housing ends to go in my '71.
My question is; should I center the housing or center the pinion?
I have heard that Ford centered the housing in order to have constant pinion angle laterally or side-2-side as well as the vertical pinion angle. I would rather have equal length axles and the housing centered but am willing to center the pinion if needed.
All advice is greatly appreciated.
Respectfully,
Adam
Adam
'71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750
2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC
'00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed
'09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD)
1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785
1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis.
AJohn6 is offline   Reply With Quote
Old 06-21-2012, 11:27 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: A 9" rearend question for the "Mad Scientists"
If it were me, I would ask the tech at Curries. No one knows 9" Fords better than them.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-21-2012, 11:39 AM   #3
robnolimit
robnolimit's Avatar
I always (shouldn't sat that) use a pinion centered housing, as it keeps the driveshaft straight back. - For cars/trucks built for show, I would use a housing centered for looks.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 06-21-2012, 01:16 PM   #4
Portmod7
Portmod7's Avatar
Originally Posted by robnolimit View Post
I always (shouldn't say that) use a pinion centered housing, as it keeps the driveshaft straight back.
x2
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 06-21-2012, 11:59 PM   #5
oldspowered67C10
Id center the housing so that you are guaranteed to have bearing movement in the u-joints even if the the drive shaft, trans and pinion are perferfectly parallel to the ground but truthfully it probably doesnt matter too much.
oldspowered67C10 is offline   Reply With Quote
Old 06-22-2012, 10:32 AM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
Centered pinion makes more room for mufflers.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 06-22-2012, 10:48 AM   #7
AJohn6
Knuckle head
AJohn6's Avatar
Ok, this is great. Are there anymore pro's and con's I can get on either set-up?
Also, I am pretty sure I posted this in the wrong section, my apologies.
Respectfully,
Adam
Adam
Old 06-22-2012, 10:59 AM   #8
Scottshotrods
Center your pinion in your frame to keep your driveshaft straight.'
Justin
Scottshotrods is offline   Reply With Quote
Old 06-22-2012, 11:09 AM   #9
AJohn6
Knuckle head
AJohn6's Avatar
Justin
Justin,
When I get home I will need to send back the rear Wilwood kit for one with the late model big ford bracket. I made a last minute decision to get rid of the 12 bolt. I will call you when I get home and we can discuss this more. Thanks for your help last week.
Respecfully,
Adam
Adam
Old 06-22-2012, 11:23 AM   #10
Scottshotrods
No problem call us up and we will help you out and take care of you
Justin
