06-21-2012, 11:09 AM | #1 |
buffle
unwanted lights
When we turn the headlights on , the turn signal lights in dash come on. I have checked all the outside bulbs , could it be the flasher? Any help would be appreciated.
Life is like a roll of toilet paper. The older it is, the faster it is used up. |
06-21-2012, 11:15 AM | #2 |
Arrived on a Pale Horse
Re: unwanted lights
Sounds like maybe a ground issue, or lack of.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
06-21-2012, 11:58 AM | #3 |
78K & 79C Jimmys
Re: unwanted lights
done any work on the cluster?
check cluster board, shifted around the socket at turn markers? either that or is the cluster plug loose/off centred from the copper strips? but grounds back there work wonders for other isses too
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
06-21-2012, 01:46 PM | #4 |
buffle
Re: unwanted lights
yes all the lights are fine except these two light up when the headlights are turned on.
06-22-2012, 09:20 AM | #5 |
buffle
Re: unwanted lights
I`ve checked the bulbs, grounds and everything else I can think of. I guess next I`ll take out each bulb and check for corrosion.
06-22-2012, 09:26 AM | #6 |
Re: unwanted lights
Grounds... I added an additional ground to one of my tailights, and all my problems went away.
06-22-2012, 12:41 PM | #7 |
Re: unwanted lights
So just clip a norther ground to the main ground wire and just bolt it to the frame?
On a quite night you can hear a ford rust |
06-22-2012, 12:58 PM | #8 |
Re: unwanted lights
I went into the light and ran a ground to a clean spot on the frame.
Prior to that, might lights were dim and when I put a signal light on they both would flash slowly..sometimes they just wouldn't work at all. |
06-22-2012, 02:15 PM | #9 |
Re: unwanted lights
I had a problem with the right side signals not workin with the running lights, so I replaced all the bulbs with l.e.d replacement bulbs and now the left side is giving the same problem as ur saying, the dash signal light stays on and doesn't make the lights flicker
06-22-2012, 03:22 PM | #10 |
Re: unwanted lights
Are the arrows in the dash super bright like they would be if they were flashing properly? or kind of dim and glowing?
06-22-2012, 03:56 PM | #11 |
Re: unwanted lights
Kinda dim and glowing
06-22-2012, 03:57 PM | #12 |
buffle
Re: unwanted lights
Everything seems normal outside the truck. brake lights, lights and turn signals. But inside once the headlights are on the two turn signal lights constantly stay lit and don`t flash with the blinkers. With the headlights off everything is normal inside and out.
Life is like a roll of toilet paper. The older it is, the faster it is used up. Last edited by buffle; 06-22-2012 at 03:58 PM. Reason: misspelled word |
06-22-2012, 04:03 PM | #13 |
Re: unwanted lights
I sorta have the same problem except just the right blinker in the dash comes on when I turn the parking lights on.
Haven't found the cause yet, but I am gonna check or run some new grounds
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
06-22-2012, 04:34 PM | #14 |
Re: unwanted lights
Mine started as everything worked but the right front turn signal had a connection problem and the back one always stayed fully lit with the driving lights and headlights on but with. Them off everything worked fine but the front turgnal because of connection problems, so I got new led replacement bulbs and now the right side works fine but now the left side doesn't work with the signals, the brake light works and the front signal running light works but no signal and the indicator on the dash stays dimly lit
06-23-2012, 10:29 AM | #15 | |
Re: unwanted lights
Installed a new flasher , pulled the button out and problem solved. Desert |
06-26-2012, 05:31 PM | #16 |
buffle
Re: unwanted lights
anyone else?
06-26-2012, 05:37 PM | #17 |
C/10 junkie
Re: unwanted lights
I just delt with this last night on my 68. One of the screws that went through the printed circuit for a ground was missing. I replaced the screw and all is good.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
06-26-2012, 05:44 PM | #18 |
Re: unwanted lights
It pretty much has to be a bad ground causing things to backfeed the indicators. Pull the connectors on the bulbs and test the grounds with a multimeter. You should get 1/2 ohm or less between the ground terminal in the socket and the - battery post. If it's more than 1/2 an ohm trace the circuit all the way back to the battery. Anywhere it's bolted to the frame or body should be unbolted, cleaned, and reattached.
Edit: Start testing on the head light connectors, but do the turn signals and tail lights too. |
06-27-2012, 02:21 PM | #19 |
78K & 79C Jimmys
Re: unwanted lights
anybody work on the clusters?
any bulbs put in where there were none? if no other issues..... maybe some power is running back threw the cluster board turn markers and dimmer and choke are all close in the cluster and appear to use the same ground
06-27-2012, 03:59 PM | #20 |
Re: unwanted lights
I worked on my cluster but everything worked fine after I put it in but then a week efter my passanger side turn signals stopped working, I replaced my bulbs with the new led replacment ones and now the drivers side dosent work but is slightly glowing on the dash and the passangerside is fine now
06-27-2012, 07:01 PM | #21 | |
78K & 79C Jimmys
Re: unwanted lights
But I'd check the copper paths@ it too Posted via Mobile Device
06-27-2012, 11:53 PM | #22 | |
Re: unwanted lights
06-28-2012, 12:03 AM | #23 | |
78K & 79C Jimmys
Re: unwanted lights
06-28-2012, 12:03 AM | #24 |
Re: unwanted lights
Headlight switch or flasher. Anything else on the circuit? Maybe jump the bulbs from the inst. Panel to the headlight switch? If you bypass the flasher with a wire to the headlight switch its probably not the switch.
Posted via Mobile Device |
